Problem involving Newton's 2nd law of motion
The problem involves an arrow launched from a bow, initially at rest, with a specified launch speed of 25.0 m/s. The question explores the implications of doubling the average force exerted on the arrow while keeping other conditions constant, specifically regarding the arrow's launch speed.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the implications of the phrase "all else remaining the same," questioning whether it refers to time or displacement. Some explore the relationship between force, acceleration, and velocity using kinematic equations, while others express confusion about achieving the correct velocity for the first scenario.
The discussion is ongoing, with participants offering insights into the relationships between force, acceleration, and velocity. Some have provided guidance on maintaining unit consistency in calculations, while others are still grappling with the implications of doubling the force and how it affects the arrow's speed.
Participants note that the displacement of the arrow is assumed to remain constant, which influences their calculations and reasoning about acceleration and velocity. There is a recognition that without knowing the displacement, it is challenging to find a numerical solution for acceleration.
vkrock
An arrow, starting from rest, leaves the bow with a speed of 25.0m/s. If the average force exerted on the arrow by the bow were doubled, all else remaining the same, with what speed would the arrow leave the bow?
F = ma
For a force, F, the launch velocity of the arrow was 25.0m/s. Acceleration is F/m and multiplying F/m by a time t gives velocity at time t. So I re-wrote the first scenario as 25.0m/s = t/m * F. In the second scenario the force is doubled (2F), so I re-wrote the velocity as Xm/s = t/m * 2F. Since t and m remain the same for both scenarios, is the velocity of the 2nd scenario simply that of the 1st scenario's but doubled (50m/s)?
One has to ask, what does that mean? i.e. the time remains the same or the displacement of the draw.
Doubling the force on the same mass would double the acceleration, and for the same the displacement, that would reduce the time of the launch.
more detail
By all else remaining constant, it means that the arrow's displacement (x) remains the same. That seemed to be the general class consensus. The acceleration doubles when the force is doubled, that makes sense, but the next step (actually finding the velocity of such an arrow) is giving me some trouble.
What I've done is try to solve some of the kinematic equations to get expressions for displacement and time from which I can calculate velocity; I am running into troubles, because for the first arrow (acceleration = a) I can't get the velocity to come out as 25m/s, i always get half that.
This is the approach I am taking:
First arrow: V0 = 0m/s, V = 25m/s, Acceleration = a, Displacement = x
Finding x in terms of a:
V^2 = V0^2 + 2ax
625 = 2ax
312.5/a = x
Finding t in terms of a:
V = V0 + at
25 = at
25/a = t
Finding 1st a using new expression for and t:
V = V0 + at
25 = 312.5/a * 25/a
25 = 7812.5/a^2
a^2 = 7812.5/25
a = sqrt(7812.5/25) = 17.68 m/s2
check: V = 17.68 * 25/17.68 = 25m/s
Using initial acceleration*2 to find velocity after a doubled force (acceleration)
V = V0 + at
V = (17.68*2) * 25/(17.68*2)
V = 35.36 * 25/35.36
V = 25
The same velocity? The expressions seem to work ok for the 1st arrow's conditions, 17.68m/s acceleration matches the 25m/s launch velocity given in the problem. Can anyone help me figure out what's going wrong?
V = V0 + at
25 = 312.5/a * 25/a
Why did you substitute the expression for x as the value for a? If you had kept the units you would have seen that what you did here is invalid. So what are the units?
Good so far; you even have units on the initial velocity (0 m/s rather than 0).
V^2 = V0^2 + 2ax
625 = 2ax
312.5/a = x
V = V0 + at
25 = at
25/a = t
Now you are dropping units. This would be much better done as
[tex]\begin{aligned*}<br /> v^2 &= v_0^2 + 2 a x \\<br /> 2 a x &= 625\; \text{m}^2/\text{s}^2 \\<br /> x &= \frac{312.5\; \text{m}^2/\text{s}^2}{a} \\ & \\<br /> v &= v_0 + at \\<br /> at &= 25 \text{m/s} \\<br /> t &= \frac{25\; \text{m/s}}{a}<br /> \end{aligned*}[/tex]
There is no way to find a numerical solution for the acceleration a because you don't know the displacement x. You can, however, still determine what would happens when the acceleration doubles.
  • · Replies 42 ·
  • · Replies 17 ·
  • · Replies 24 ·
