Need help on vector analysis :(
by R3DH34RT
Tags: analysis, vector
R3DH34RT
R3DH34RT is offline
#1
Sep25-07, 02:20 PM
P: 31
Guys, I need ur help please... Can u help me to answer these problems? I'm very confused...
1. Show that the vector Ai + Bj + Ck is normal to the plane which equation is Ax + By + Cz = D, where A, B, C, D are constants
2. n = 0.5i + 0.5j + 0.7071k is the unit-normal for plane A. b = 4i + 5j + 2k, c = 2i + 3j + k. Calculate the area of parallelogram project from b x c to plane A. Calculate components of vectors b and c that are parallel to plane A.
3. New right hand coordinate axes are chosen at the same origin with e1' = (2e1 + 2e2 + e3)/3 and e2' = (e1 - e2) x 1.4. Express e3' in term of e1. If t = 10e1 + 10e2 - 20e3, express t in terms of the new basis ek'. Express the old coordinate xi in term of xk' , xi = f(xk')
Please help me guys... :( Thanks a lot...
Phys.Org News Partner Science news on Phys.org
Lemurs match scent of a friend to sound of her voice
Repeated self-healing now possible in composite materials
'Heartbleed' fix may slow Web performance
EnumaElish
EnumaElish is offline
#2
Sep25-07, 02:24 PM
Sci Advisor
HW Helper
EnumaElish's Avatar
P: 2,483
What are the relevant equations? How do you define "normal"? What is a projection? How do you define "parallel"?
R3DH34RT
R3DH34RT is offline
#3
Sep25-07, 02:31 PM
P: 31
normal is perpendicular to the plane
HallsofIvy
HallsofIvy is offline
#4
Sep25-07, 03:12 PM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 38,879
What do you know about the inner product of two perpendicular vectors?
R3DH34RT
R3DH34RT is offline
#5
Sep25-07, 07:38 PM
P: 31
The inner product of 2 perpendicular vector is zero, right?
But, is there any relationship? :(
mcampbell
mcampbell is offline
#6
Sep26-07, 04:08 AM
P: 14
Do you have anymore information about D? What do you know about equations of a plane?
R3DH34RT
R3DH34RT is offline
#7
Sep26-07, 08:19 AM
P: 31
No, I don't have more information about D.
I think that's already the equation of a plane?
Thanks.
D H
D H is offline
#8
Sep26-07, 10:02 AM
Mentor
P: 14,432
Let [itex]\boldsymbol x_0 = (x_0, y_0, z_0)[/itex] be some specific point on the plane. Let [itex]\boldsymbol x = (x, y, z)[/itex] be any point on the plane. Can you write equations that describe the points [itex]\boldsymbol x_0[/itex] and [itex]\boldsymbol x[/itex]? What is the inner product of the vector from [itex]\boldsymbol x_0[/itex] to [itex]\boldsymbol x[/itex] with the vector [itex]\boldsymbol n = (A,B,C)[/itex]?
R3DH34RT
R3DH34RT is offline
#9
Sep27-07, 07:47 AM
P: 31
D is just a constant.
The equation of a plane is should be the normal of the vector, right?
R3DH34RT
R3DH34RT is offline
#10
Sep27-07, 07:49 AM
P: 31
Do you mean (x-x0)/x + (y-y0)/y + (z-z0)/z = 0?
The inner product should be zero, right?
D H
D H is offline
#11
Sep27-07, 08:26 AM
Mentor
P: 14,432
Quote Quote by R3DH34RT View Post
No. Where did you get the division?
Yes, but this is what you need to prove.
Expanding on my previous post:
Quote Quote by D H View Post
Because both [itex]\boldsymbol x_0[/itex] and [itex]\boldsymbol x[/itex] are on the plane, [itex]Ax_0 +By_0+Cz_0 = D[/itex] and [itex]Ax +By+Cz = D[/itex].
(1) What is the difference between these equations?
(2) What is the vector from [itex]\boldsymbol x_0[/itex] to [itex]\boldsymbol x[/itex]?
You are given that [itex]\boldsymbol n = (A,B,C) [/itex].
(3) What is the inner product between [itex]\boldsymbol n[/itex] and the vector from [itex]\boldsymbol x_0[/itex] to [itex]\boldsymbol x[/itex]?
Don't guess. Use the answer to question 2. Finally, relate the answers to questions 1 and 3.
R3DH34RT
R3DH34RT is offline
#12
Sep27-07, 08:40 AM
P: 31
The vector from x0 to x is (x-x0) right?
So should I do the inner product between (x-x0) . (n)?
Then I won't get any number, just some equation in x n x0?
D H
D H is offline
#13
Sep27-07, 08:51 AM
Mentor
P: 14,432
Yes. Do that. The reason for doing this is that the vector [itex]\boldsymbol x - \boldsymbol x_0[/itex] represents any arbitrary vector on the plane. If a vector is normal to every vector on some plane the vector is normal to the plane itself.
Please use English, not TXT-speak. Is it really that much harder to type x and x0?
R3DH34RT
R3DH34RT is offline
#14
Sep27-07, 10:52 PM
P: 31
OK... I'll do that...
Can you please help me with number 2 and 3?
R3DH34RT
R3DH34RT is offline
#15
Sep30-07, 11:29 PM
P: 31
Hi, can anyone help me with the other question please...?
I am so depressed... :(
Need some hints... Thanks...
D H
D H is offline
#16
Oct1-07, 02:52 AM
Mentor
P: 14,432
Redheart, you really do need to show some work before most people here will help you.
R3DH34RT
R3DH34RT is offline
#17
Oct1-07, 11:58 AM
P: 31
I calculated the cross product of b x c, buat I don't know what is the meaning of "projection to plane A"
But for number 3, I can't figure out the meaning. Can you please give a hint?
Thanks...
HallsofIvy
#18
Oct1-07, 02:12 PM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 38,879
It tells you what to do in the next sentence: "Calculate components of vectors b and c that are parallel to plane A". Find the projection of b x c on the normal vector you found in 1, subtract it from b x c to find the part parallel to the plane.
Thanks...
Are these new coordinate axes still orthogonal to one another? Check the inner product of e1' and e2' that you are given to make sure. Assuming they are orthogonal, then e3' must be orthogonal to both. How do you find a vector orthogonal to two given vectors? Of course, you have to be careful of the sign- this has to be a right hand coordinate system.
Register to reply
Related Discussions
Vector Analysis Help Calculus & Beyond Homework 4
vector analysis Science & Math Textbook Listings 6
vector analysis identity Advanced Physics Homework 4
Vector Analysis Precalculus Mathematics Homework 1
Vector Analysis Introductory Physics Homework 9
