High Impedance in Verilog????
by l46kok
Tags: impedance, verilog
l46kok
l46kok is offline
#1
Sep27-07, 07:56 PM
P: 296
Provide the correct Verilog text for encoding the following numerical values:
A) A 16 bit hexadecimal with all positions in the high impedance state:
B) An unsized hex number BEEF
2. Relevant equations
Verilog Problem. There is no relavant equation to be used.
3. The attempt at a solution
What the.. I didn't even know a variable can literally be declared as high impedance. I thought high impedance state occurs when the variable is neither off or on.
Also, I thought the variables you declare in verilog MUST be sized.
How are these accomplished?
Phys.Org News Partner Science news on Phys.org
Better thermal-imaging lens from waste sulfur
Hackathon team's GoogolPlex gives Siri extra powers
Bright points in Sun's atmosphere mark patterns deep in its interior
shuh
shuh is offline
#2
Sep29-07, 06:00 PM
P: 6
Quote Quote by l46kok View Post
You actually can have the states as high-impedance. In your case, it would be
16'h????
or
16'hz
would work.
There is no such thing as unsized hex number. Even if you forget to declare the size, by default, verilog would size it as 32 bit.
Register to reply
Related Discussions
Help with Verilog Engineering Systems & Design 0
Does anybody know verilog? Electrical Engineering 1
project to detect open collector/ high impedance signals Electrical Engineering 5
verilog help Electrical Engineering 2
Verilog help Electrical Engineering 2
