| Thread Closed |
Moments |
Share Thread | Thread Tools |
| Sep28-07, 03:21 PM | #35 |
Moments
I cant seem to work it out correctly the force is L/2 away from the pivot and in order to work out the tension I must do something must I make T perpendicular ?
| Sep28-07, 03:24 PM | #36 |
Mentor
You treat the tension in problem 2 exactly as you did in problem 1.
| Sep28-07, 03:29 PM | #37 |
Mentor
You might want to study these examples: Torque Equilibrium Examples
| Sep28-07, 03:34 PM | #38 |
Right to in problem 1 we basically made it perpendicular correct ? So for now lets call the lenght L meaning that 200*L=200*T*sin30, sin30 because that will give use the hypotenues which is T but the problem with the formula is that it gives the same answer as we got in question 1 meaning we must divide sin30 on each side meaning 200*L/sin30= 400 and once we find out the L we will get an new answer perhaps.
| Sep28-07, 03:57 PM | #39 |
Mentor
200*L = L*T*sin30 If you are talking about problem 2, the left side of the equation is different. The distance is not L, but L/2. The right side remains the same, since the cable has not moved and the angle is the same. Rewrite the equation for problem 2 and solve for the tension. Again, the length of the beam (L) will drop out. |
| Sep28-07, 05:22 PM | #40 |
Yes I think i understand 200*L/2=L*T*sin30
Which becomes 200/sin30/2 400/2=T 200=T |
| Sep28-07, 05:30 PM | #41 |
Mentor
Good! In the second problem it takes just half the tension to support the beam.
| Sep28-07, 05:41 PM | #42 |
| Sep28-07, 06:00 PM | #43 |
Mentor
| Sep28-07, 06:05 PM | #44 |
600*L/2=L*T*sin30. |
| Sep28-07, 06:24 PM | #45 |
Mentor
| Sep28-07, 06:34 PM | #46 |
| Sep29-07, 04:28 AM | #48 |
| Sep29-07, 06:23 AM | #49 |
Mentor
Now set this sum of clockwise torques equal to the counter-clockwise torque due to the tension to the get the equilibrium equation: 300*L = L*T*sin30 Now you can solve for the tension in problem 3. |
| Sep29-07, 07:11 AM | #50 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Moments
| Moments | Introductory Physics Homework | 2 | ||
| Moments | Advanced Physics Homework | 11 | ||
| Moments | Engineering, Comp Sci, & Technology Homework | 4 | ||
| nuclear magnetic moments and electric quadrupole moments | General Physics | 0 | ||
