A circuit with capacitor and resistor
The discussion revolves around a simple electric circuit that includes a capacitor and a resistor connected in parallel with a voltage supply of approximately 25V. Participants are exploring the behavior of current through the capacitor and resistor under different assumptions about the capacitor's state of charge.
  • Participants are examining the implications of a capacitor being fully charged versus it being in a state of constant charging and discharging. Questions arise regarding the assumptions made about the current through the capacitor and resistor, particularly in relation to the voltage supply.
The discussion is active, with participants providing insights and clarifications regarding the behavior of the circuit components. Some guidance has been offered about the theoretical aspects of ideal components, but there is no explicit consensus on the interpretation of the capacitor's state.
There are mentions of ideal components and theoretical scenarios, suggesting that real-world factors such as internal resistance of the voltage source are not being considered in the current discussion.
jazzchan
A circuit with capacitor and resistor !
Dear all,
it is a simple electric circuit include one capacitor and one resistor in parallel. about 25V is provided. Then i assume I1 cross the capacitor and I2 cross the resistor. Therefore, when a capacitor has a constant change, can i assume the I1 current flowing to zero, then I2 is V=RI ??
thanks a lot !
It's kind of tricky, I'm going to do my best here but you might want to wait for another answer.
I think it depends on what you mean by "a capacitor has a constant change". If you mean that it's fully charged, then yes, the current through it would be zero. However it can mean that the capacitor is constantly charging and discharging at the same rate, so the charge of it stays the same but there is still current through it. I think the latter is what's happening in this case, since I don't see how a capacitor can be fully charged when it's connected in parallel with a battery and a resistor.
Yes.
One little nitpick on the phraseology: voltage is across, current goes through. This seems nitpicky, but it will probably help you understand circuits better if you are strict with it.
BTW, if you assume ideal components, then this situation obtains immediately, since an ideal capacitor would take 0 time to charge to any arbitrary voltage supplied directly from an ideal voltage source.
One caveat, this is a purely theoretical situation as there is no voltage source with zero internal resistance and infinite current to produce a charged capacitor instantaneously.
  • · Replies 24 ·
