How Can You Partition Symmetry Groups Using the Multiplication Table Method?
This discussion focuses on partitioning symmetry groups using the multiplication table method, specifically the symmetry group C3v, also known as D_3 or S_3. The author successfully partitions the group into distinct conjugacy classes: {E} for identity, {C3, -C3} for rotations, and {r1, r2, r3} for reflections. The method involves calculating products of the form zxz^-1 to determine the conjugacy classes, which can be easily done by hand for smaller groups. The conversation highlights the relationship between cycle types and conjugacy classes in symmetric groups.
  • Understanding of group theory concepts, particularly symmetry groups.
  • Familiarity with conjugacy classes and their significance in group theory.
  • Knowledge of multiplication tables in the context of group operations.
  • Basic understanding of cycle types in permutation groups.
  • Study the construction and properties of multiplication tables in group theory.
  • Learn about conjugacy classes in detail, focusing on their applications in symmetry groups.
  • Explore cycle types and their role in determining conjugacy classes within symmetric groups.
  • Investigate representation theory and its connection to symmetry and group structures.
Mathematicians, students of abstract algebra, and anyone interested in group theory and its applications in symmetry and geometry.
H-bar None
I reading a great book called Symmetry by Roy McWeeny. For those that love Dover Books this one's a gem.
Anyway, I have a question.
How do you partiton a particular group into distinct classes?
The author was discussing the symmetry group C3v the rotation, and reflection of a triangle.
The author was able to partition this group by using its multiplication table. The classes are {E}, {C3,-C3} and {r1,r2,r3}.
Where E is identity, C3,-C3 are positive and negative rotations, r1,r2,r3 are the reflections.
How did he get this answer?
I hope my ? is clearly stated.
That would depend upon which classes you mean. I presume you mean conjugacy classes. In general you need to take some element x and work out what all the product zxz^-1 ,which we presume the author did by looking at the multiplication table, are, that set of products is then the conjugacy class.
Here it's simple to do by hand. For larger cases one must be cleverer, but in the case of the symmetric group the conjugacy class is uniquely determined by the cycle type. C3v, also called D_3 or D_6 is the same as S_3 the permutation group on three letters. The letters here being the corners of the triangle. A reflection swaps two of them and fixes one, so it can be written as (12)(3) for some labelling of the corners. It has cycle type 2.1, or just 2. A rotation permutes three of them and can be written as (123) say which has cycle type 3. Read the bit on symmetric/permutation groups to see that in more detail.
Thanks for the help. I cut out a triangle, labeled the points and worked the multiplication table manually. Learned a lot.
Now onward to vector spaces and lattices with the rest stop at representaion theory. :biggrin:
10K
  • · Replies 20 ·
