How Does the Choice of Delta Affect an Epsilon-Delta Proof?
  • Thread starter Thread starter bjgawp
    Proof
The discussion revolves around the epsilon-delta definition of limits, specifically focusing on the limit of the function \(3 - 2x^2\) as \(x\) approaches \(-1\). Participants are exploring how different choices of \(\delta\) affect the validity of their proofs and the implications of those choices.
  • Participants are questioning the impact of assuming different values for \(\delta\), such as 5 or 0.5, on the proof's validity. They discuss whether these assumptions lead to more accurate or valid results.
  • There is a focus on the logic behind certain inequalities, particularly the assumption that \(2(3)|x+1| < \epsilon\) and how it relates to finding an appropriate \(\delta\).
  • Some participants express confusion about the reasoning behind certain steps in the proofs, particularly regarding the manipulation of inequalities and the assumptions made during the process.
The discussion is ongoing, with participants actively engaging in clarifying concepts and questioning the assumptions made in their proofs. Some guidance has been provided regarding the importance of controlling the size of certain variables, but there is no explicit consensus on the best approach yet.
Participants are working within the constraints of epsilon-delta proofs, which require careful consideration of the relationships between \(\delta\) and \(\epsilon\). There is an acknowledgment of the need for assumptions to facilitate the proof process, but the validity of these assumptions is under scrutiny.
bjgawp
Prove that [tex]\lim_{x\to\\-1}(3-2x^{2})=1[/tex] The problem isn't figuring out the problem but rather a question about the answer itself.[/
None really.
http://img248.imageshack.us/img248/913/prooffi5.jpg
My question is that what's the difference if we assumed [tex]\delta[/tex] to be another number such as 5? We would wind up with [tex]\delta[/tex] = min{5, [tex]\epsilon[/tex]/14}. How would the two answers differ? Is one answer more accurate or more "right" than the other?
If [itex]\delta[/itex] is "assumed to be another number such as 5" then it wouldn't work would it? The whole point is to make certain that |2- 2x2|< 1 isn't it?
Was that supposed to say [itex]|2 - 2x^2| < \epsilon[/itex]?
I also assume you meant to say "If we had instead assumed [itex]\delta \leq 5[/itex]..."? If you get an answer, then you get an answer. The answer is not unique.
For the record, that image has a minor logic error in it. And even if we ignore that, it's not a complete solution.
Ooh forgot about that :redface: .
Alright instead of [tex]\delta[/tex] = 5, what about [tex]\delta \eq[/tex] = 0.5? We would get [tex]\delta[/tex] = min{0.5, [tex]\epsilon[/tex]/5}. Again, is this answer more "valid" than [tex]\delta[/tex] = min{1, [tex]\epsilon[/tex]/6}
EDIT: Missed Hurkyl's post. Thanks again! Yeah, I didn't feel like going through the whole formality of the proof. Just wanted to get the point across. Thanks!
Like I said, if you get an answer, then you get an answer! This sort of technique is rather forgiving; it's rather common that choosing any number between 0 and [itex]+\infty[/itex] for your bound on [itex]\delta[/itex] will lead you to an answer.
Just out of curiosity, what minor logic error did you refer to? Might help me solve a particular problem I've been having with these proofs.
Where I've said 2|x+1||x-1| < 2(3)|x+1| < [tex]\epsilon[/tex], why is it that we assume 2(3)|x+1| < [tex]\epsilon[/tex]? Seems like we arbitrarily assumed it to make the solution work ... Thanks in advance guys!
Good call; that's exactly what I was referring to.
The work in this image -- the "working backwards" preliminary work -- is assuming the conclusion: [itex]|2 - 2x^2| < \epsilon[/itex]. From our other assumption, we also know that [itex]|2 - 2x^2| < 2(3)|x+1|[/itex]. However, we cannot conclude that [itex]2(3)|x + 1| < \epsilon[/itex]. (At least, not immediately)
What we need here is, as you've realized, another assumption. (Though if we make the assumption so that the solution will work, it's not exactly arbitrary. :wink:)
We made the assumption that [itex]\delta \leq 1[/itex] so that we could control the size of [itex]|x - 1|[/itex]. Now, since [itex]2(3)|x+1|[/itex] has appeared naturally, we make the additional assumption that [itex]2(3)|x+1| < \epsilon[/itex] to wedge it into the problem right where we want it.
By making these assumptions, we arrive at an answer that works, so we're happy! But if we were unable to arrive at an answer, we would have to try something else.
Remember that none of this work is the actual solution -- it's the process of working backwards from the answer to figure out what to use as a starting point. Once we have a starting point (e.g. "let [itex]\delta = \min\{1, \epsilon/6\}[/itex]"), then we can work forwards to prove that this really is a solution.
Compare with solving algebra problems -- you manipulate the problem until you get potential solutions, and then you have to plug them back into the original equation to see if they really are solutions. The plugging-in part what you need to do to prove they are solutions -- but the manipulations are the process you used to figure out what the solutions had to be.
Thank you very much! Things are a bit more clearer than they were. However, just another question. I'm still not see how assuming 2(3)|x + 1| < [tex]\epsilon[/tex] leads us to find the "right" [tex]\delta[/tex]. Just because [tex]\delta \leq[/tex] 1, where's our basis that even with the restriction we placed on |x - 1| that 2(3)|x+1| should be < [tex]\epsilon[/tex]. Just curious where the connection is :) Thanks, once again, for taking your time!
Your goal is to find a choice of [itex]\delta[/itex] that makes [itex]|2 - 2x^2| < \epsilon[/itex].
You have already shown that if [itex]\delta \leq 1[/itex], then [itex]|2 - 2x^2| < 2(3)|x+1|[/itex].
This gives you a lead -- if you can arrange things so that both [itex]\delta \leq 1[/itex] and [itex]2(3)|x+1| < \epsilon[/itex] are true, then you have accomplished your goal.
So, to continue working backward, you make the additional assumption that [itex]2(3)|x+1| < \epsilon[/itex], and see if that helps you deduce anything.
You aren't guaranteed that this will help you find the solution -- but this is something to try. And often, the simple thing works!
Ooh! That clears it up for me. Do you know of an example where that assumption does NOT work? You don't have to go through the trouble of finding one as you've helped a lot already. Thank you very much :) Now .. onto making sense of proving the limit laws ...
This very problem is a good example. :smile:
Suppose you didn't think to make the assumption that [itex]\delta \leq 1[/itex]. Then, in the process of working backwards, you might do
[tex]|2 - 2x^2| = 2 |1-x| |1+x| < 2 \delta |1 - x|.[/tex]
Then, the natural thing to do would be to assume that [itex]2 \delta |1 - x| < \epsilon[/itex] and see what happens. Solving for delta, you get:
[tex]\delta < \frac{\epsilon}{2 |1 - x|}[/tex]
Unfortunately, since x can be any value at all, [itex]|1 - x|[/itex] can be arbitrarily large, and this forces us to choose [itex]\delta \leq 0[/itex], which we cannot do.
Incidentally, after meeting this failure, the next step to realize "Okay, the problem is that I had no control on the size of [itex]|1 - x|[/itex]" -- it is this chain of thought that leads you to make an assumption like [itex]\delta \leq 1[/itex].
  • · Replies 20 ·
  • · Replies 48 ·
  • · Replies 25 ·
