Some kind of LC sound resonator?
The discussion revolves around the concept of creating a sound resonator capable of generating voltage at frequencies in the hundreds of Hz range. Participants explore various construction ideas and methods for achieving this goal, focusing on the resonator's design and functionality.
  • Exploratory, Technical explanation, Conceptual clarification
  • One participant suggests brainstorming ideas for constructing a sound resonator that can generate voltage.
  • Another participant proposes the idea of using a tube partially filled with water, questioning whether it could resonate at a specific frequency and produce voltage.
  • A different participant mentions the possibility of using a woofer speaker as a pickup or converter, recommending the addition of a large reflector to focus sound onto the speaker face.
  • One participant emphasizes the need for the resonator to be frequency-specific rather than converting all sounds into current.
Participants present multiple competing views on the construction and functionality of the sound resonator, and the discussion remains unresolved regarding the best approach.
Oblio
Hey all,
I'm trying to brainstorm a way to get a sound resonator (the order of hundreds of Hz) to create a voltage.
I'm not exactly sure what the resonator should be constructed of... any ideas?
Is it conceivable to use a tube-semi filled with water? I realize this will in fact resonate at a certain frequency, but could a voltage be obtained somehow?
You can also use a woofer speaker as a pickup/converter, especially if you construct a big reflector element to focus the sound down to the speaker face.
the reason why I'm considering something along the lines of a resonance tube, is because I want it frequency specific.. not just all sounds into a current...
know what i mean?
  • · Replies 19 ·
