Seting up the Integral: Electric Potental Energy
The discussion focuses on setting up the integral for calculating electric potential energy (PE) in the context of charge distributions. The key formula for electric potential is given as V = k∫_V (ρ/r) dτ, where ρ represents charge density and r is the distance from the charge element. Participants emphasize the importance of dividing charge distributions into small elements to apply the formula effectively, using volume, surface, and line integrals as necessary. The conversation highlights the need for understanding symmetry in charge distributions to simplify calculations.
  • Understanding of electric potential energy concepts
  • Familiarity with integral calculus
  • Knowledge of charge distributions and density (ρ, σ, λ)
  • Basic principles of electrostatics
  • Study the application of the integral V = k∫_V (ρ/r) dτ in various charge distributions
  • Learn about the effects of symmetry on electric potential calculations
  • Explore examples of electric potential due to different geometries (disk, washer, solid sphere)
  • Review the mathematical derivation of charge density formulas: Q = ∫_V ρ dτ, Q = ∫_A σ dA, Q = ∫ λ dx
This discussion is beneficial for physics students, educators, and anyone studying electrostatics, particularly those focusing on electric potential energy and charge distributions in various geometrical configurations.
cogman
I hope that this belongs here, so here is what I would love help with. We are doing Electric potential energy in class right now (and we did electric field prior) but I am struggling with the form the integral needs to take. Once I get it, I can do the math, but it is just understanding all the parts that confuse me.
So here is what I know,
[tex]V = kq/r[/tex] is the formula for 2 points
[tex]V = \int_{surface} k dq/dr[/tex] I believe (not so sure)
[tex]dq = \int_{surface} dP/V[/tex] Where V is volume, area, length.
Is this all correct? Or what am I missing? I would love some examples of how you guys would do it. For my class we are using mostly highly symmetric situations (IE how does a disk, washer, solid sphere effect electric potential of some point perpendicular to) so feel free to make your own up to illistrate the point.
Again thanks for the help. I was unsure on putting this in the homework section as it is not a homework problem I have a question about, but the concept instead.
The formula for Electrostatic PE is simple if you have point charges. When you have a charge distribution things get a bit more complicated. Essentially what you want to do is divide a charge distribution into small bits, that way you can apply the original formula to each small bit of charge and add them all up to get the end result.
Mathematically, to divide up a charge distribution use one of the following formula as appropriate. Note that the charge densities, rho, sigma and lambda might vary with position.
Volume: [itex]Q = \int_V \rho d\tau[/itex]
Surface: [itex]Q = \int_A \sigma dA[/itex]
Line: [itex]Q = \int \lambda dx[/itex]
So now (taking volume as an example) you can write;
[tex]V = k\int_V \frac{\rho}{r}d\tau[/tex]
At this point you have divided up the charge distribution into many small point charges, each with charge [itex]\rho.d\tau[/itex], calculated the contribution to V from each one, then summed them all via the integral.
From here, the problem will progress depending on the symmetry present.
Claude.
  • · Replies 21 ·
  • · Replies 30 ·
