Register to reply
Operator in non-orthogonal basis
by j_dirac
Tags: basis, nonorthogonal, operator
Share this thread:
j_dirac
#1
Oct4-07, 05:47 PM
P: 6
Hi, is possible make up a operator in a non-orthogonal basis, if is possible how I can contruct the operator.
thanks
Phys.Org News Partner Physics news on Phys.org
Physical constant is constant even in strong gravitational fields
Physicists provide new insights into the world of quantum materials
Nuclear spins control current in plastic LED: Step toward quantum computing, spintronic memory, better displays
quetzalcoatl9
#2
Oct4-07, 08:26 PM
P: 701
why not form your operators as |b><a|
j_dirac
#3
Oct5-07, 10:11 AM
P: 6
which are the consequence of choice a basis non-orthogonal?
A/4
#4
Oct5-07, 11:25 AM
P: 46
Quote Quote by j_dirac View Post
Why do you want to form an operator in a non-orthogonal basis in the first place?
nrqed
#5
Oct5-07, 11:44 AM
Sci Advisor
HW Helper
P: 3,025
thanks
Of course.
All you need to know is the effect of the operator on all the basis states. So if you know all the values of [itex] <a_i|A|a_j>[/itex] then you know everything about the operator.
Alternatively, as quetzalcoatl9 pointed out, an arbitrary operators can be written as
[itex] A = \sum c_{ij} |a_i><a_j| [/itex]
One consequence of having a non orthonogonal basis is that you can't read off directly from the above expression what is the effect of applying the operator to a basis state gives.
If the basis is orthogonal, then applying A to, say, [itex] |a_3> [/itex] will simply give [itex] c_{13} |a_1> + c_{23} |a_2> + \ldots [/itex] (I am assuming that the labels of the states are discrete and start at 1). If the basis is not orthogonal, the expression is of course more complicated.
j_dirac
#6
Oct5-07, 01:01 PM
P: 6
I can construct a basis depent of basis non-orthogonal, how might make up? and what happen with the eigenvalues and elements of the operator.
someone know if the situation present in some quantum system.
Register to reply
Related Discussions
Inner products and orthogonal basis Linear & Abstract Algebra 4
Dot product of basis vectors in orthogonal coordinate systems Calculus & Beyond Homework 5
Orthogonal basis Linear & Abstract Algebra 29
Operator change of basis (QM / QI) Linear & Abstract Algebra 6
Orthogonal projection, orthonormal basis, coordinate vector of the polynomial? Linear & Abstract Algebra 1
