Math Beauties in need of HELP!
  • Thread starter Thread starter marlen
The discussion revolves around the question of why the set of irrational numbers is not considered an open subset of the real numbers. Participants are exploring the definitions and properties of open sets in the context of real analysis.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Some participants attempt to reason through the properties of irrational numbers and their relation to open sets, questioning whether intervals around irrational numbers contain only irrationals. Others explore the implications of cardinality and the existence of rational numbers within any interval around an irrational number.
Participants are actively engaging with the concepts, with some providing insights into the definitions of open sets and the nature of intervals in the real numbers. There is a recognition that intervals around irrational numbers must contain rational numbers, leading to a deeper exploration of the implications of this fact.
Some participants express confusion regarding the definitions and properties being discussed, indicating a need for further clarification on the relationship between open sets and the distribution of rational and irrational numbers within the real numbers.
marlen
the question is...why the set of irrational numbers is not an open subset of Real numbers?
none that i am aware of
can we say that...
assume that the irrational numbers are open. but we know that the set of real numbers is infinite and much larger than the set of irrational numbers. therefore, there is not a one to one mapping of irrational numbers to rational numbers.
Please help us. we are so lost. it would be greatly appreciated.
Well, make a tiny open interval around an irrational number.
Does that interval only contain irrationals?
can we say that...
In the reals what is the complement of the irrational numbers? Is this set open or closed?
Being open or not has nothing to do with cardinality. Instead look at the definition of "open set".
Do you know this: given any two real numbers, x< y, there exist an irrational number z such that x< z< y. If p is any rational number rational number, then for any [itex]\delta> 0[/itex] there exist an irrational number in [itex](p-\delta , p+\delta )[/itex]. Is p an interior point of the set of rational numbers? What does that tell you about whether the set of rational numbers is open or not?
That's just what arildno said a few seconds ahead of me!
No, the interval will contain either another irrational number or a rational number.
120, to be exact, Halls! :smile:
Is such a thing allowable if the set of irrationals were to be open?
The complement of irrational numbers is the set of rational numbers. and this set can't be closed or open, i think...because the real numbers is an open set and i know that the union of two open sets is open. but irrational numbers are not open, so I'm stuck
Well, but the union of two non-open sets can perfectly well be open, can't it?
no. ... so what you are saying is that if we have an irrational number x, and for some small r>0 we get the interval (x-r, x+r) which contains either a rational or irrational number, meaning we cannot draw an open-ball around our x, meaning that the set of irrationals cannot be open.
i suppose but does that matter
You were the one in the preceding post who was "stuck" on precisely that issue.
You are, however, right, so there is no reason for you to remain stuck on it, since it happens to be irrelevant.
Precisely!
Q.E.D. :smile:
I'm not really sure how to answer this question.
arildno said:
Precisely!
Q.E.D. :smile:
but we can't just assume that there lies a rational or irrational number in the the interval of (x-r, x+r) can we?
Just adding a note:
For every r>0, the open r-interval about the irrational number will contain (infinitely many) rationals.
Therefore, the irrational set cannot be open.
arildno said:
Just adding a note:
Yea, but you can't just say that. I know it's true but how do i show that.
We certainly can:
Remember, any REAL number can adequately be given, say, a decimal representation.
Now, pick an irrational, regard its decimal expansion.
Now, truncate that infinite sequence of decimals into a finite sequence, and you get a RATIONAL number.
Thus, you may construct a sequence of rationals CONVERGING upon the irrational, i.e, there will be rationals arbitrarily close to any, and every, irrational number.
Thank you arildno and everyone else who helped us. It makes sense now! ;)
Actually the important thing is that every interval of the reals contains a rational number. Therefore every interval around every irrational point contains a point that is not in the set of irrationals. Therefore the irrationals are not an open set.
For the irrationals to be open there would need to be an interval around each irrational containing just irrationals. But there isn't. Most likely your professor or your text has a proof showing that each interval of the reals contains a rational and therefore the irrationals are not open.
So prove it, since it is very elementary (irrational numbers have rational approximations, and the other case is even easier).
  • · Replies 85 ·
9K
