Thread Closed
Collision of two Balls
Share Thread Thread Tools
Oct6-07, 11:05 PM   #1
Ball 1 (B1) and Ball 2 (B2) are located at (x,y)=(0,0) and (x,y)=(d,h).
At t=0, B1 is sent towards the initial location of B2 with a speed vi. At the same
instant that B1 is launched, B2 falls towards the ground with zero initial velocity.
Assume there is no air resistance.
A diagram is attached below.
1. When and where do B1 and B2 collide?
2. If the initial speed of B1 is larger than vi, does a collision occur?
3. If B1 is directed towards a point slightly above the initial location of B2, can a
collision occur?
4. If B2 has an initial speed Vi in the negative y-direction, can B1 collide with B2?
2. Relevant equations
1. v_f = v_i + a[tex]\Delta[/tex]t
2. s_f = s_i +v[tex]\Delta[/tex]t +1/2a[tex]\Delta[/tex]t^2
3. v_f^2 = v_i^2 +2a[tex]\Delta[/tex]s
4. s_f = s_i + v[tex]\Delta[/tex]t
3. The attempt at a solution
Okay, I am really, really confused about this problem, but I tried #1.
I solved for the distance that Ball 1 travels using equation 4 and got:
s(ball 1) = cos[tex]\theta[/tex]v_it_1
Then for Ball 2 I used equation 2:
S(BALL 2) = h + 4.9t_1^2
Then I made both these equal each other:
h + 4.9t_1^2 - cos[tex]\theta[/tex]v_it_1 = 0
Now I know I can solve for time using quadratic formula but I'm not sure how to find where the balls meet. Also I am completely lost on how to solve for the rest of the questions. Please, someone help me out!! Any help is appreciated!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Oct8-07, 09:11 PM   #2
you can't use equation four because it is not constant velocity, (gravity has a role) therefore you'd have to use equation two twice for B1 and B2 then have the two equal because that will give you time of collision (it won't be a quadratic) then use T to get distance. Btw you used Cos(theta) when its Sin because its vertical component. and you know the x distance is d because thats where B2 is dropped so use vertical distance of B1 and d to find co-ordinate of the collision. i did it just now everything worked out fine.
Thread Closed
Thread Tools
Similar Threads for: Collision of two Balls
Thread Forum Replies
collision between two croquet balls Introductory Physics Homework 7
Collision of two pool balls Classical Physics 4
Collision between two balls Introductory Physics Homework 16
collision of two balls. Introductory Physics Homework 3
balls collision Introductory Physics Homework 2
