Solving Acceleration of Blocks in Pulley System
The discussion revolves around a pulley system involving two blocks, where participants are tasked with finding the acceleration of each block in terms of their masses and gravitational acceleration. The original poster has attempted to apply Newton's second law and has drawn free body diagrams to analyze the forces acting on each block.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the relationships between the accelerations of the two blocks, questioning how the acceleration of one block relates to the other. There is an emphasis on understanding the dynamics of the system and the implications of the free body diagrams drawn.
The discussion is ongoing, with participants seeking clarification on the relationships between the accelerations of the blocks. Some guidance has been offered regarding the need to explore the physical setup further, particularly in understanding how the movement of one block affects the other.
Participants are working with a visual representation of the pulley system that may not be entirely clear, leading to requests for clarification. There is an acknowledgment of the need to establish the correct relationships between the accelerations of the blocks.
Thomas_
Pulley System:
Code:
B-------O	////
	 ---O---
	    B
O = Pulley
B = Block
Find the acceleration of each block in terms of m1,m2 and g.
F = ma
I drew free body diagrams for each block and ended up with:
Block 1: T1 = m1a1
Block 2: m2g - T2 =m2a2
T2 = 2T1
However, this is not enough to cancel out all a2's / a1's. What piece am I missing here?
What's the relationship between a_1 and a_2? If m1 has an acceleration of +a to the right, what must the acceleration of m2 be?
not much is clear from that picture.. mind clarifying it a lil bit??
The same?
I'm sorry, sure.
http://img299.imageshack.us/img299/3518/clipboard01kg4.th.jpg
Thomas_ said:
The same?
No. If m_1 moves a distance L to the right, how far down does m_2 move? (You might find it helpful to play around with a piece of string. I'm not kidding.) You need to determine the magnitude and direction of the acceleration of m_2 in terms of the acceleration of m_1.
  • · Replies 34 ·
  • · Replies 102 ·
9K
