How Do Tension Changes Affect the Frequency of Violin Strings?
  • Thread starter Thread starter eku_girl83
    Frequency
The discussion focuses on the relationship between tension changes and the frequency of violin strings. Two identical strings, initially tuned to 196 Hz, were retuned, resulting in a frequency range of 194.5 Hz to 197.5 Hz, with 1.5 beats per second detected between them. The fractional change in tension was calculated using the formula T_2 = (f_2/f_1)^2 * T_1, leading to an increase of approximately 0.01276% for 197.5 Hz and a decrease of about 0.00205% for 194.5 Hz.
  • Understanding of fundamental frequency and tension in strings
  • Familiarity with the formula for beats per second
  • Knowledge of the equation for fundamental frequency: f = (1/2L)*sqrt(T/m)
  • Basic grasp of square root relationships in physics
  • Explore the impact of string length on frequency in string instruments
  • Learn about the physics of sound waves and their interaction with tension
  • Investigate the effects of mass per unit length on string vibration
  • Study advanced topics in wave mechanics related to musical acoustics
Musicians, physicists, and string instrument makers interested in the acoustics of violin strings and the mathematical relationships governing their behavior.
eku_girl83
Well, I've encountered a couple more problems...
Here they are:
Two identical violin strings, when in tune and stretched with the same tension, have a fundamental frequency of 196 Hz. One of the strings is retuned by adjusting its tension. When this is done, 1.5 beats per second are heard when both strings are plucked simultaneously. I found the lower and upper limits on the possible fundamental frequencies of the re-tuned strings to be 194.5 and 197.5 Hz, respectively. I'm struggling with this:
By what fractional amount was the string tension changed if it was increased?
By what fractional amount was the string tension changed if it was decreased?
(delta T)/T
Could someone help me with this? Thanks!
Here they are:
(delta T)/T
Frequency depends on the square root of the tension. Since you have the frequencies and the original tension, I think that's enough to solve it.
It sounds like you have encountered some interesting problems with frequency and tension in regards to violin strings. As for your questions, determining the fractional amount of change in tension can be a bit tricky but here is a possible approach to solving it. First, we can use the formula for beats per second, f_beat = f_2 - f_1, where f_2 is the frequency of the retuned string and f_1 is the original frequency of 196 Hz. We know that 1.5 beats per second were heard, so we can plug that in and solve for f_2. This gives us f_2 = 197.5 Hz.
Now, we can use the formula for fundamental frequency of a string, f = (1/2L)*sqrt(T/m), where L is the length of the string, T is the tension, and m is the mass per unit length. Since the strings are identical, we can assume that m is the same for both strings. We also know that L is constant and does not change. So, we can set up the following equation:
f_1 = f_2 = (1/2L)*sqrt(T_1/m) = (1/2L)*sqrt(T_2/m)
Solving for T_2, we get T_2 = (f_2/f_1)^2 * T_1. Plugging in our values, we get T_2 = (197.5/196)^2 * T_1 = 1.0001276 * T_1. This means that the tension was increased by approximately 0.01276% (0.0001276) in order to produce a frequency of 197.5 Hz.
Similarly, if the tension was decreased, we can use the same formula and solve for T_2. We would get T_2 = (194.5/196)^2 * T_1 = 0.99795 * T_1. This means that the tension was decreased by approximately 0.00205% (0.0000205) in order to produce a frequency of 194.5 Hz.
I hope this helps and good luck with your further exploration of frequency and tension in violin strings!
  • · Replies 26 ·
