Current Carrying Wires-No force b/t them?
  • Context: Undergrad
  • Thread starter Thread starter brianparks
    Current Force
The discussion centers around the behavior of current-carrying wires and the forces they exert on each other, as predicted by Faraday's law. Participants explore the outcomes of an experiment involving wires in a power cord and the implications of AC versus DC current on these forces.
  • Experimental/applied
  • One participant describes an experiment where two current-carrying wires were placed in parallel and anti-parallel configurations, expecting to observe attractive and repulsive forces as predicted by Faraday's law, but reported no observable force.
  • The same participant speculates that the rubber coating on the wires might be affecting the magnetic field, although they note they have not encountered any literature suggesting this.
  • Another participant hints at the possibility that the current in the power cord may cancel out due to the configuration of the wires, suggesting that the net current through the wire is zero.
  • A later reply acknowledges the simplicity of the explanation regarding the cancellation of currents in the power cord but seeks clarification on the experimental setup and the measurement of forces involved.
  • Questions are raised about the safety and methodology of the experiment, particularly regarding the handling of the power cord and the measurement of the forces, which are noted to be very small at typical separations and currents.
Participants do not reach a consensus on the initial experiment's setup and results, with some clarifying the nature of the wires involved and others questioning the methodology and assumptions made.
There are unresolved aspects regarding the experimental conditions, including the handling of the power cord and the method of measuring the forces between the wires. The discussion also highlights the dependence on the configuration of the wires and the nature of the current (AC vs. DC) without reaching a definitive conclusion.
brianparks
Current Carrying Wires--No force b/t them?
Faraday's law predicts that two current-carrying wires, when placed parallel to each other, will exert an attractive force on each other. Conversely, two wires that are placed anti-parallel to each other will exert a repulsive force on each other.
While I was vacuuming my apartment today, I decided to test this phenomenon. I folded the wire into two parts such that one part of the wire was touching the other, with its current flowing in the opposite direction. The result? Nothing. According to Faraday's law, however, the wires should have exerted an attractive force on each other.
I then folded the wires such that one part was touching the other, with its current flowing in the same direction. The result? Again, nothing. But according to Faraday's law, the wires should have exerted a repulsive force on each other.
How can I make sense of this result?
Of course, the electrical input is AC 60hz, not DC. But this shouldn't matter. If the wires are parallel to each other, then on the positive half cycle, both currents will be in the same direction, and the wires will exert a repulsive force on each other. Likewise when the input is on its negative half cycle. The frequency of the input would not seem to make any difference.
Maybe the rubber coating around the wire stifles the magnetic field created by the current flow? I've never read anything that would suggest this.
Any comments would be greatly appreciated.
brianparks,
Hint: Suppose your vacuum's drawing 5 amps, what's the net current through the wire? Actually, it's a cord (that's another hint!).
Doh! One cord, two wires inside, one with current going into the load, the other with current coming out. So they cancel. It never occurred to me that the answer was so simple--and that the question was so stupid!
Anyway, thanks for clearing that up :biggrin:
Whoa, now, wait a second. Can you explain further. I didn't understand your experiment.
What does your experiment have to do with vacuuming the apartment?
What wires are you talking about (the ones in the power cord)? Did you cut up the power cord to access the wires (not all that safe :rolleyes: )? Did you just consider the power cord as a wire?
How did you measure the force? (This is my most curious question. If you've ever done this experiment in a controlled lab environment, or even just calculate it, you'll know that the force is absolutely miniscule at a separation on the order of millimeters at a current on the order of amps. I.e. separation of 1 mm between two lengths of wire a foot long carrying 10 A gives you a magnetic force about equal to the weight of a single pea).
  • · Replies 61 ·
  • · Replies 32 ·
  • · Replies 27 ·
