Solving Problems Using the Pigeonhole Principle
  • Context: Undergrad
  • Thread starter Thread starter Caldus
    Hole Principle
The discussion revolves around applying the Pigeonhole Principle to solve two specific problems: one involving the distribution of refugees across buses and the other concerning the learning of new vocabulary words over a set number of days. Participants explore how to define 'boxes' and 'objects' for these problems and seek guidance on formalizing their reasoning.
  • One participant expresses understanding of the Pigeonhole Principle but struggles to apply it to the problems presented, specifically in forming the 'boxes' and 'objects'.
  • Another participant suggests that if all buses carried the same number of people, then each bus would carry approximately 66.66 passengers, leading to the conclusion that at least one bus must carry 67 passengers.
  • A different participant introduces the idea that if no bus carries more than 66 people, then the total number of people would be less than 2000, implying that at least one bus must carry at least 67 passengers.
  • Discussion on the second problem indicates that George must learn at least one word per day, leading to the need to show that there exists a span of consecutive days where he learns exactly 15 words.
  • Some participants attempt to illustrate the distribution of words learned over days with examples, suggesting that there are multiple ways to achieve the required distribution.
  • One participant proposes a method involving equivalence classes and modular arithmetic to show that the sums of words learned must yield a specific result, although they express uncertainty about the correctness of their approach.
  • Another participant questions the use of different day counts in the reasoning and seeks clarification on the implications of assuming the statement is false.
Participants express varying levels of understanding and approaches to the problems, with no consensus reached on the best method to apply the Pigeonhole Principle to the second problem. Disagreements arise regarding the interpretation of the problems and the validity of proposed solutions.
Participants highlight the complexity of the problems and the need for careful reasoning, with some suggesting that case-by-case analysis may be necessary. There are unresolved mathematical steps and assumptions regarding the distribution of words and the implications of the Pigeonhole Principle.
Caldus
I get the principle itself, but I cannot figure out how to form the 'boxes' and the 'objects' for these problems so that I can try to answer them:
1. Thirty buses are to be used to transport 2000 refugees from Gander to St. John's, Newfoundland. Each bus has 80 seats. Assume one seat per passenger. Prove that one of the buses will carry at least 67 passengers.
2. George has promised to increase his vocabulary by learning the meanings of 90 new words during his summer holidays. Suppose he has 53 days in which to accomplish this task and will learn at least one new word a day. Show that during some span of consecutive days, George will learn precisely 15 new words.
Pointing me in the right direction with either of these will be greatly appreciated.
Mathematics news on Phys.org
It has been so long since I have read anything on the pigeonhole principle that I probably will not be able to guide you in deriving an answer in the way the instructor wants you to.
If I just wing it, I would say this:
Suppose all buses carried the same amount of people. Then each bus would carry 2000/30=66.66 people. Since the bus driver would get into legal trouble for showing up at the destination with a fractional refugee, the realistic solution in which the busloads are as equitable as possible is 67 people on some buses and 66 people on some buses. Shifting people out of any of the buses carrying either 66 or 67 people will either leave 67 as the maximum number on any bus, or else increase the maximum number on any bus to 68, or to 69, or to 70...
But maybe you have already gotten this far, and the point is to formalize the reasoning to a greater degree than I have been able to.
This is pure maths, so it isn't the pigeon hole principle "result" that is important so much as its "proof"
so suppose that on none of the buses there is more than 66 people, then there are at most 66*80 < 2000 people,
(you can consider this the extended pigeon hole principle)
the second one is puzzling me
first he learns at least one of the 90 on each day, thus leaving 37 to distribute amongst the 53 days, we must show that no matter how that is done then there is a set of consecutive days where he learns 15 words... can't quite get it yet..
All the second one says is that there is at least 1 day where there is only a single word learnt, no?
cookiemonster
It says more than that - a smaller example, 5 words 3 days must be distributed in one eof the following words per day:
3,1,1 or 1,3,1 or 1,1,3 or 1,2,2 0r 2,1,2 or 2,2,1
in each case there is some day or consecutive days where exactly three words are learnt.
it also states that there are at least 53 -37 = 16 days with exactly one word learned in the original question.
i just can't see a better way of doing it than case by case at the moment
OK, I think I have a little bit of an idea for the second one (thanks a lot for pointing me in the right direction with the first one):
Suppose that the objects are how many words he learns on a given day:
An = Number of new words learned on day n.
So:
A1 = A1
A2 = A1 + A2
An = A1 + A2 ... + An
And the boxes consist of equivalence classes 1, 2, 3, ... 14 (since 15 would be congruent mod 1 in this case).
This means that 2 sums must be congruent mod 14 and the difference must be divisible by 14.
Let these two sums be:
A1 + A2 ... + Ak
A1 + A2 ... + Ak + Al (k and l are integers)
The difference of these two sums is:
Ak+1 + Ak+2 + ... + Al
I think I am way off with the actual proof, but I think I have good idea of what to do now. I just can't quite figure it out. Any help appreciated.
the second equality you write implies A2=0
don't confuse the number learned on day n, An, with those learned by day n, call it Bn:
Bn=A1+...+An
i think this is discrete mathematicz...anywayz, I am not sure if I am rite...
you draw two ovals...one with 1 to 90 holes in it and the other with 53 holes in it...according to the pigeon hole principle, the 53 holes[days] will point to the other 53 holes [words]. leaving us with 90-53=37 words.
the question iz "Show that during some span of consecutive days, George will learn precisely 15 new words." now, for the 37 which is left, we can just distribute them into the first 37 days leaving us with 2 words for the 1st 37 days...we can say 15 words were learned from day 31 to 38 [7*2 + 1 = 15]
lets try the other possiblilty...we will try to place them as far away from each other...thus, we will start filling the 53 holes with 37 words by separating each word by 1 days...so day 1 has 2 words, day 2 has 1 word and day 3 has 2 words, day 4 has 1 word etc etc...we can notice that this way only 27 words get filled till the 53rd day...now we just have 37-27=10 words to will into the 53holes. now no matter where we place those 10 words we will have the sequence of 2 s and a 1 in the border of the sequence...so therez 2*7 + 1=15 words learned in conseq days...
Im not sure if this is right...did this really fast...my answer does not seem like a mathematical proof...ill be glad to see few more ways of doing this.
There are another 53^37 - 2 possibilities to consider, sunilkamadolli. Good luck. (Ok it's not that many really, but it's close enough as to still be impossible)
OK, trying this again:
Suppose that the statement is false. In other words, suppose that George did not learn exactly 15 new words within a number of consecutive days. Let Wj be the number of words learned on day j where 0 <= j <= 42. Let Tj be the total number of words learned by day j where 0 <= j <= 42. So:
Objects:
T1 = W1
T2 = W1 + W2
Tn = W1 + W2 + ... + Wn
The "boxes" in this case would be the equivalence classes 0, 1, 2, ... , 14. This means that 2 sums must be congruent mod 14 and the difference of these two sums must be divisible by 14. Let these two sums be:
W1 + W2 + ... + Wk
W1 + W2 + ... + Wk + Wl (k and l are integers)
The difference of these two sums would be:
Wk+1 + Wk+2 + ... + Wl
If this statement were false, then there would be no two sums which were congruent mod 14 and the difference of these two sums would never be divisible by 14. One counterexample of this is that at some point George will have to know more than one word, so suppose that:
W1 = 1
W2 = 1
W13 = 1
W14 = 2
In this case George will have learned 15 new words in 14 days. So the statement is true.
Any better? Still needs a lot of work I bet...
Wht are we now using 42 and not 53 days? There mus be ar least 4 differences which are zero mod 14. I don't understand what you are doing when you say: if this statement were false. which statement? and why is one counterexample sufficient? I think you may have found a good anlge here, but don't hold me to that.
  • · Replies 45 ·
  • · Replies 35 ·
  • · Replies 25 ·
  • · Replies 124 ·
18K
  • · Replies 67 ·
17K
  • · Replies 65 ·
9K
  • · Replies 94 ·
14K
