Register to reply
Kinetic Friction
by Heat
Tags: friction, kinetic
Share this thread:
Heat
#1
Oct8-07, 09:39 AM
P: 273
Consider the system shown in the figure. Block A has weight w_A and block B has weight w_B Once block B is set into downward motion, it descends at a constant speed.
Calculate the coefficient of kinetic friction between block A and the table top.
A cat, also of weight w_A, falls asleep on top of block A. If block B is now set into downward motion, what is the magnitude of its acceleration?
Express your answer in terms of w_A, w_B and g.
2. Relevant equations
F=ma
w=ma
3. The attempt at a solution
I know that when the box is sliding at constant speed the kinetic friction is: Fsubk = [tex]\mu[/tex]subk n .
The thing is I don't know where to start, as there are no numbers.
I would know that the block b is gravity pulling down.
Phys.Org News Partner Science news on Phys.org
World's largest solar boat on Greek prehistoric mission
Google searches hold key to future market crashes
Mineral magic? Common mineral capable of making and breaking bonds
Heat
#2
Oct8-07, 10:09 AM
P: 273
ok, I just read that an object is at equilibrium whether at rest or constant velocity.
when the crate moves, the forces would be:
Sum Fx = T - fk =0
Sum Fy = n-w = 0
Doc Al
#3
Oct8-07, 10:11 AM
Mentor
Doc Al's Avatar
P: 41,312
Do the first part first. (Duh!) Just analyze the forces and apply Newton's 2nd law to each mass separately, as usual. Take advantage of the fact that it moves at constant speed. What does that tell you?
Heat
#4
Oct8-07, 10:16 AM
P: 273
Kinetic Friction
Well I edited my previous post,
but I found that fk = T and n=w
using fk = usubkn
uk = fk/n
Doc Al
#5
Oct8-07, 10:22 AM
Mentor
Doc Al's Avatar
P: 41,312
Good:
Quote Quote by Heat View Post
Heat
#6
Oct8-07, 10:25 AM
P: 273
so the coefficient is fk/n, for part one?
The "Express your answer in terms of w_a,w_b,g " is for the second question. :)
I just placed fk/n as the answer, and I good feedback saying "The correct answer does not depend on the variables: f_k, n." :(
ok, I got it, indeed with using w as the variable. :)
malakian_77
#7
Nov2-10, 05:55 PM
P: 1
1.) ľK = Wb/Wa
2.) A cat, also of weight w_A, falls asleep on top of block A
a = [Wa*g*(Wb/Wa)] / [2*Wa + Wb ]
since the cat has a weight of A, and the block has Weight A
the above equation needs to be (2*Wa) where Wa is present.
Register to reply
Related Discussions
Why is the kinetic friction always smaller than the static friction? Introductory Physics Homework 15
Kinetic Friction Introductory Physics Homework 2
Kinetic friction Introductory Physics Homework 3
Static friction and kinetic friction Introductory Physics Homework 5
Static Friction Vs Dynamic/Kinetic Friction Classical Physics 8
