What are the effects and explanations of blue shift and red shift?
  • Context: High School
  • Thread starter Thread starter Koveras00
    Effects
Blue shift and red shift are terms used in astronomy to describe frequency shifts of light due to motion and cosmic expansion. Blue shift occurs when light's frequency increases, indicating motion towards the observer, while red shift indicates a decrease in frequency, often due to motion away or the expansion of space. The redshift is quantified using the symbol "z," where a redshift of z = 0.1 corresponds to a ten percent decrease in frequency, suggesting motion away at approximately one tenth the speed of light or a ten percent expansion of space during the light's travel.
  • Understanding of the Doppler effect
  • Familiarity with spectral lines and atomic emission
  • Basic knowledge of cosmology and space expansion
  • Knowledge of frequency and wavelength relationships
  • Study the Doppler effect in detail, focusing on its applications in astronomy
  • Learn about the calculation and implications of redshift in cosmology
  • Explore the concept of cosmic expansion and its effects on light
  • Investigate the spectral analysis of different elements, particularly hydrogen
Astronomers, astrophysics students, and anyone interested in understanding the implications of light frequency shifts in the context of cosmic phenomena.
Koveras00
Can anyone explain what is blue shift and red shift?? And what effects they have?
blue shift and red shift are the astronomers' words for
frequency shifts up or down
blue shifted light is light with the frequency shifted up
(by motion towards, doppler-fashion)
redshifted light is light with the frequency shifted down
(either by motion away, doppler, or by the expansion of
the space in between, or by a gravity effect)
the light from each kind of atom has a distinctive recognizable pattern of spectral lines, so if you see some hot hydrogen gas you can recognize that it is hydrogen and you can tell (from measurements in the laboratory with the same gas) what
frequencies it OUGHT to be emitting.
So if you measure the light that is actually getting to you and find that it is redshifted by ten percent (frequency ten percent lower, or wavelength ten percent longer) then you say "z = 0.1"
z is the conventional symbol for the redshift, the fractional (increase in wavelength, or) decrease in frequency. So a ten percent decrease in frequency means "z = 0.1".
And that corresponds to the doppler effect of motion away by approximately one tenth of the speed of light.
Or a ten percent stretchout of space during the time the light was on its way to you.
There are some fine points and an improved doppler formula and some ambiguities about what is relative motion away and what is the expansion effect, but basically the redshift z = 0.1 would be interpreted as nearly all due to a tenpercent expansion of space during the light's passage and it would be informally talked about as if it were due to the emitter moving away at one tenth the speed of light.
  • · Replies 19 ·
  • · Replies 46 ·
  • · Replies 23 ·
  • · Replies 26 ·
