Electric Field inside a cylinder
The discussion revolves around calculating the electric field inside a long cylindrical insulator with a uniform charge density. Participants are exploring the implications of Gaussian surfaces and the relationships between charge, volume, and electric field strength.
  • Participants discuss the expression for charge within the Gaussian surface and its relationship to the volume of the cylinder. There are attempts to clarify the role of the length of the cylinder in the calculations. Some participants express confusion about the presence of certain variables in their equations and question their understanding of the area calculations for the Gaussian surface.
There are multiple interpretations of the problem and various approaches being explored. Some participants have provided guidance on expressing charge and area correctly, while others are verifying their calculations against expected outcomes. The discussion is ongoing, with no explicit consensus reached yet.
Participants are working under the constraints of a homework assignment, which may limit the information available for solving the problem. There is also mention of using specific programs for homework submissions, indicating potential discrepancies in expected answers.
orb123
A long cylindrical insulator has a uniform charge density of 0.94 µC/m³, and a radius of 7cm (R). Find the electric field inside the insulator at a adistance of 4cm (r). Answer in units of N/C.
Variables:
q= charge in the gaussian surface
R= Radius of cylinder
r= radius of gaussian surface of cylinder ; r<R
L= Lenght of gaussian surface of cylinder
Equations:
EA=q/ε0
V= (pi)R²L
V'= (pi)r²L
q=pV' volume of the gaussian surface of the cylinder
Q=pV; Q= charge, p=charge density
A=2(pi)RL = Area of cylinder (only the curved surface)
Ok, I'm solving the gaussian surface of the cylinder. I know q<Q, and q=pV' = p{(pi)r²L}.
Then, I know p=Q/V by definition, so q=Q{(pi)r²L}/V.
Pluggin it into the first equation:
EA = Q{(pi)r²L}/{V(ε0)}
E{2(pi)RL}=Q{(pi)r²L}/{V(ε0)}
Solving:
E= Qr²/{2V(ε0)R} ; Then replacing V
E= Qr²/{2(pi)R²L(ε0)R} (??)
Why do I still have L there? I was not given a value for that, and it was supposed to be eliminated during solving the equations. And even if L wasn't there, the final solution would not be in units of N/C. What am I doing wrong?
Thanks!
Express the charge within your Gaussian surface as [itex]\rho V = \rho \pi r^2 L[/itex].
I think I already did that. I replaced V' in q=pV' with (pi)r²L, but I think what I did after that was wrong, but I don't know why.
Thanks for your help!
Then why do I see Qs everywhere? :wink:
Yeah, thanks!
I also realized I was solving the Area wrong. Instead of A=2(pi)RL, should be A=2(pi)rL since I am analyzing the area of the gaussian surface of the cylinder, not the area of the entire cylinder.
Thanks again.
Hey Doc Al, this is Aleksey, I'm doing same problem with different values for variables
so: p = Q/V
where r< R
and I get the final answer as exactly pr/2ε0, but when I plug in my answer into the answer post in one of the programs we use in school for HW - it's wrong. What am I doing wrong?
so: p = Q/V
where r< R
Beats me. That answer looks correct.
thanks, at least know on the right track from a Doc. Do you have a masters in Physics or you just like physics in general as an art and mentorship?
I got it, my answer was right! Thanks so much for the opinion, i kept writing the formula correctly pr/2ε0 but was plugging into my calc r^2 all the time instead of r.
How was the equation Pr/2ε0 derived?
I have a similar problem and the formula appears to be correct, but I'd like to know how you get to it
I know E = Q/ε0 = (PV)/(Aε0) = (P*pi*r^2)/(ε0(2*pi*r^2+2*pi*r*L))
I separated the equation into two and got P*L/(2*ε0)+P*r/(2*ε0). Why is it that only the latter part is the correct equation to use?
By the way, my problem involves a straight and long cylindrical charge cloud. We're given the radius and charge density, but no length.
When calculating the flux through your Gaussian surface, only the curved side of the cylinder counts since the field is radial. The flux through the end pieces is zero since the field is perpendicular to those surfaces, so those areas don't count.
