| Thread Closed |
JAVA simple array problem |
Share Thread | Thread Tools |
| Oct10-07, 04:04 AM | #1 |
Q1. Write a function that accepts an array of integers and returns the second largest integer in the array. Return -1 if there is no second largest.
The signature of the function is public class ID { public static void main(String[] args){ } int f(int[ ] a) { } } Examples: if the input array is {1, 2, 3, 4} then return 3 if the input array is {{4, 1, 2, 3}} then return 3 if the input array is {1, 1, 2, 2} then return 1 if the input array is {1, 1} then return -1 if the input array is {1} then return -1 if the input array is {} then return -1 |
| Oct10-07, 06:58 AM | #2 |
Ok, you have the signature, what about the actual code?
The examples you've given doesn't demonstrate you've attempted the program. Anyone can pick the second largest number in a set. Please show us some code. |
| Feb18-09, 04:48 AM | #3 |
public static void main(String[] args) {
// TODO code application logic here int secondlargest= -1; int largest = -1; int number[] ={4, 1, 2, 3}; for (int i=0;i < number.length;i++) { if(largest < number[i] ) { secondlargest = largest; largest = number[i]; } if(secondlargest < number[i] && largest != number[i] ) secondlargest = number[i]; } System.out.println(secondlargest); //System.out.println(largest); // System.out.println(objhwa.data); // Display the string. } |
| Thread Closed |
| Thread Tools | |
Similar Threads for: JAVA simple array problem
| [SOLVED] Simple Java Problem | Programming & Comp Sci | 2 | ||
| Sorting an Array in Java | Programming & Comp Sci | 9 | ||
| how do display/generate webpage content with info from an array in a .java file? | Programming & Comp Sci | 1 | ||
| Simple array problem | Programming & Comp Sci | 10 | ||
| converting from an array of function values to coordinate array of different length | Programming & Comp Sci | 3 | ||
