The discussion revolves around designing a circuit that utilizes 3 mechanical switches to control 8 LEDs, representing binary combinations. This is framed within the context of an electric circuits class, where participants explore methods to achieve this without using logic gates or integrated circuits.
- Exploratory
- Technical explanation
- Debate/contested
- Homework-related
- One participant inquires about the difficulty of creating a circuit with 3 switches to light up 8 LEDs without using logic gates.
- Another participant suggests using a 74138 chip, but the original poster clarifies that they cannot use logic chips.
- A suggestion is made to use transistors to create AND, OR, and NOT functions, while noting that relays could be an expensive alternative.
- One participant expresses uncertainty about how to create logic using transistors and resistors, despite understanding the truth table.
- Links to resources on using diodes and resistors to create AND and OR gates are provided.
- A participant questions what alternatives exist if logic gates are not allowed, emphasizing that many students may not yet understand logic gates due to the course structure.
- Another participant describes how switches can function as logic gates, suggesting that the arrangement of switches can control the LEDs.
- One participant mentions the possibility of using various gates available in the lab kit, including NAND gates, to construct the circuit.
- A final suggestion outlines a method using different types of switches to easily connect to the LEDs, proposing a specific wiring arrangement.
Participants express a variety of approaches and ideas, with no consensus reached on a single method for constructing the circuit. Some participants propose using transistors and resistors, while others suggest utilizing available gates from the lab kit. The discussion remains unresolved regarding the best approach to take.
Participants note limitations in knowledge about logic gates due to the course structure, which may affect their ability to engage with the problem fully. There is also mention of potential costs associated with certain components, such as relays.
