Understanding the Two Solutions for Derivatives of (2x+y)/(x-3y)=4
  • Context: Undergrad
  • Thread starter Thread starter Inspector Gadget
The discussion revolves around the problem of finding the derivative of the equation (2x+y)/(x-3y)=4 using implicit differentiation and an alternative method. Participants explore the differences in results obtained from these methods and the implications for correctness in a testing context.
  • Homework-related
  • One participant notes that using implicit differentiation directly yields a derivative of y/x, while rearranging the equation leads to a derivative of 2/13.
  • Another participant suggests that the correct answer is 2/13, arguing that y' should be expressed as a function of x to reach this conclusion.
  • A participant expresses frustration over being marked wrong for using a method that seemed simpler and more straightforward, despite obtaining what they believed to be the correct answer.
  • There is a suggestion that the problem may have been intended to be solved using implicit differentiation specifically, which could explain the grading decision.
  • One participant emphasizes that different educational institutions may have varying rules regarding adherence to specified methods in problem-solving.
Participants express differing views on the validity of the two methods for finding the derivative and whether the grading was justified. There is no consensus on which method is more appropriate or correct, and the discussion remains unresolved regarding the implications of the grading practices.
Participants note that the equation represents a straight line, which may influence the interpretation of the derivative. There are also concerns about the clarity of the problem's instructions and how they relate to the methods used.
Inspector Gadget
This was given as a problem...
[tex]\frac{2x+y}{x-3y}=4[/tex]
Now, if you just solve it as is, using implicit differentiation, you get the deriviative to be y/x.
However, if you multiply by the denominator, you get...
[tex]2x+y = 4(x-3y)[/tex]
...or...
[tex]2x+y=4x-12y[/tex]
...and if you do implicit differentiation, you get the deriviate to be 2/13.
Why are there two solutions like that, and is any of the two any more right than the other?
since y = 2x/13, I'm not sure i see what your problem is.
Inspector Gadget asked: "Why are there two solutions like that, and is any of the two any more right than the other?"
Yes, the correct answer is 2/13. You're trying to find y', which is a function of x. So when you get to the solution y' = y/x, you need to solve for y as a function of x to complete your solution for y'. As Matt Grime showed you, when you plug y(x) into y'(x) you get 2/13.
In this case it would seem that implicit differentiation doesn't do you much good. Might as well just solve the orignal algebraic equation for y and then differentiate explicitly.
Yeah, that's basically what I was asking.
We were tested on implicit differentiation last week, and I simply did the second method by multiplying by the denominator instead of having to do the quotient rule, then FOIL twice, simplify, etc., and got 2/13. It was marked wrong. I asked why and showed all my work to prove that you get 2/13, man at the helm said just said it wasn't correct. I honestly didn't even realize that the equation gives you a straight line at the time when I was arguing if you solve for y, so that should make it even easier to get my point across now.
As you were tested on implicit differentiation, then the question presumably meant you to use implicit differentiation, and not rearrangement, so I can see why the answer was marked 'wrong', even if I don't agree with the 'man at the helm's' response when he didn't explain why it was wrong. If the question asks you to solve using a specific method and does not explicitly state that you are allowed to use other methods, then you must use the method specified, irrespective of if the other method is simpler. If you wish to use another method you must prove that it produces the same answer, which is quite a big task, and you didn't state as that y=2x/13 the answers are equivalent.
I'll have to see what exactly the directions said, but his response seemed to come off as "the deriviative you supplied isn't a deriviative of the equation" than "you didn't follow the directions".
And usually, if you don't follow directions, you get half credit if you get the correct answer.
I'll definitely seem him for class by Thursday...I'll have to nag him about it again.
Well different people, different rules and all that - if you did that [didn't use the method as instructed] at my university, or even at high school, you got no marks.
  • · Replies 16 ·
  • · Replies 25 ·
