Solving Particle Motion Along y-Axis Problem
The problem involves a particle moving along the y-axis, with its position defined by a specific function of time. Participants are tasked with finding values related to the particle's position, velocity, and acceleration at given times, as well as calculating the total distance traveled over a specified interval.
  • The original poster attempts to calculate the position, velocity, and acceleration of the particle at specific times, expressing uncertainty about the correctness of their results.
  • Some participants question the interpretation of the direction of motion and suggest a method for calculating total distance by considering the roots of the displacement equation.
  • There is a discussion about the appropriateness of using the distance formula for part d of the problem.
The discussion is ongoing, with participants providing guidance on how to approach the calculations and clarifying the distinction between distance and displacement. There is no explicit consensus on the correctness of the original poster's attempts, but suggestions for improvement have been offered.
Participants are navigating the constraints of homework rules, which may limit the types of assistance they can provide. The original poster's calculations and interpretations are under scrutiny, and assumptions about the motion of the particle are being questioned.
gonzalo12345
A particle moves along the y-axis with position defined by y(t) = -1/2cos(t^2) + 7/2 t≥ 0
a. find(2)
b. in which direction is the particle moving at time t=1.5?
c. find the acceleration of the particle at time t=1.5 Is the velocity of the particle increasing at t=1.5 Why or why not?
d. Find the total distance traveled by the particle from t=0 to t=2
related rates, derivatives
I tried to solve the problem but I don't know if its right in some parts, so can somebody help me to see if there is something wrong, thanks
for part a I got y(2) = 3.83
for part b v(t) = tsint^2
v(1.5) = 1.5sin(1.5^2)
= 1.167
for part c: a(t) = sin(t^2) + 2(t^2)cos(t^2)
a(1.5) = -2.04
No, because the acceleration and the velocity doesn't have the same sign
for part d
of t=0 ---> t=2
y(0) = 3
y(1) = 3.2
t(2) 3.8
distance = (3.8 - 3) = 0.8
The part letter b asks only for a direction, so the answer should either be positive or negative. In part letter d, you would do better to identify the roots of the displacement equation and find the displacements in each direction (the intervals separated by the zeroes), and then add the absolute value of the results up. This is because the particle is traveling in one dimension and the question asks for distance and not displacement.
edit
so for d can I use the distance formula?
9K
