| Thread Closed |
Finding Kinetic Energy of Person Spinning on Chair w/ Weights |
Share Thread | Thread Tools |
| Oct11-07, 09:37 PM | #1 |
How do you find the Kinetic Energy of a person spinning on a chair with 2 equal weights on each arm?
A specific problem asks what the change in KE is if he moves his originally extended arms inward. I tried doing (1/2)(I)(wf)^2 - (1/2)(I)(wi)^2 where wi is initial angular velocity and wf is final angular velocity, but its wrong. Any help? |
| Oct11-07, 09:47 PM | #2 |
Recognitions:
What numbers/variables do they give?
| Oct11-07, 09:55 PM | #3 |
Ahh, sorry, I suppose I should have included this information in the main thread. My bad.
Well I is the same for initial and final, which is 8. Therefore, Initial I = 8 Final I = 8 Initial w = .7 Final w = 1.15 So I did: (1/2)(I)(wf)^2 - (1/2)(I)(wi)^2 = (1/2)(8)(1.15)^2 - (1/2)(8)(.7)^2 = 5.31118 - 1.96 = 3.35118116 j ...but apparently it's wrong. |
| Oct11-07, 10:10 PM | #4 |
Recognitions:
I can't be the same initial and final... if he brings his arms in the moment of inertia changes. post the question exacty as it is stated...
| Oct11-07, 10:28 PM | #5 |
Alright. But just fyi, I know it cant be the same I because the r changes, but the problem says to just assume its the same. I used the same I for initial and final to get the wf, and it was correct, so i know I is same initial and final. Anyways, heres the problem:
A student sits on a rotating stool holding two 3 kg objects. When his arms are extended horizontally, the objects are 1 m from the axis of rotation, and he rotates with angular speed of 0.7 rad/sec. The moment of inertia of the student plus the stool is 8 kgm^2 and is assumed to be constant. The student then pulls the objects horizontally to a radius 0.29 m from the rotation axis. a) Calculate the final angular speed of the student. Answer in units of rad/s. (The answer to this part is 1.15232 rad/s) b) Calculate the change in kinetic energy of the system. Answer in units of J. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Finding Kinetic Energy of Person Spinning on Chair w/ Weights
| Free body diagram of a person sitting on a wheeled chair | Introductory Physics Homework | 3 | ||
| Simple FBD problem: person, chair, earth | Introductory Physics Homework | 3 | ||
| spinning around a cylinder with a person inside | Introductory Physics Homework | 5 | ||
| spinning on chair | Introductory Physics Homework | 1 | ||
