Register to reply
Zwiebach string theory quesiton
by ehrenfest
Tags: quesiton, string, theory, zwiebach
Share this thread:
ehrenfest
#1
Oct12-07, 12:37 AM
P: 1,996
One thing that has been bothering me about the light-cone gauge that Zwiebach uses is that we have equations such as 9.63 and 9.71 in which X^+ and X^- are given by completely different expressions.
I am not sure why this makes sense physically since we can interchange X^+ and X^- just by moving to coordinate system in which X^1' = -X^1. So, shouldn't it be arbitrary which coordinate is X^+ and X^- and if it is arbitrary and coordinate-system dependent, how can physics depend on which way we choose our coordinate system?
2. Relevant equations
3. The attempt at a solution
Phys.Org News Partner Science news on Phys.org
What lit up the universe?
Sheepdogs use just two simple rules to round up large herds of sheep
Animals first flex their muscles
Jimmy Snyder
#2
Oct12-07, 03:38 AM
P: 2,179
Quote Quote by ehrenfest View Post
[itex]X^+[/itex] and [itex]X^-[/itex] are not 'physics', they are coordinates. [itex]L_0^{\perp}[/itex] on the other hand, is physics. Equation (9.77) shows that changing [itex]X^1[/itex] with [itex]-X^1[/itex] has no effect on the physics.
ehrenfest
#3
Oct12-07, 01:14 PM
P: 1,996
OK. I see your point.
But I guess my point is that there is no reason why the light cone +'s and -'s in 9.63 and 9.71 should not be reversed. Somewhere Zwiebach must have just made some assumption that arbitrarily distinguished X^- from X^+ . Obviously he is free to do this but I am just looking for the point where X^+ and X^- "diverge".
Jimmy Snyder
#4
Oct12-07, 01:53 PM
P: 2,179
I'm not sure if this is the answer you are looking for, but here goes anyway. The assumption he made was just above equation (9.61) where he defines the light-cone gauge as imposing conditions (9.27, page 155) with a vector n that gives [itex]n\cdot X = X^+[/itex], i.e. [itex]n = (\frac{1}{\sqrt2}, \frac{1}{\sqrt2}, 0, ...)[/itex].
Edit - What follows is garbage. I will correct it in a later post.
So what would happen if he went the other way and imposed the conditions (9.27) with a vector n that gives [itex]n\cdot X = X^-[/itex], i.e. [itex]n = (\frac{1}{\sqrt2}, \frac{-1}{\sqrt2}, 0, ...)[/itex]? I don't know because I haven't worked it out. However, the easy guess is that nothing would happen except for swapping + and - signs here and there.
ehrenfest
#5
Oct12-07, 02:31 PM
P: 1,996
OK.
The sentence above 9.61 says that "Selecting the light-cone gauge means imposing the conditions (9.27) with a vector n^mu that gives nX = X^+"
So, is this where he arbitrarily chose a + sign instead of a minus sign? If the sentence had read:
"Selecting the light-cone gauge means imposing the conditions (9.27) with a vector n^mu that gives nX = X^-"
would that have contradicted something he said previously about the light-cone guage?
Jimmy Snyder
#6
Oct12-07, 02:58 PM
P: 2,179
Yes. He was defining the meaning of the phrase 'light-cone gauge'.
I don't see how it could. I think this is the first place in the book that the light-cone gauge is mentioned. The index gives no earlier reference. Again, this is a definition, not an observation.
Jimmy Snyder
#7
Oct12-07, 04:28 PM
P: 2,179
I'm sorry Ehrenfest, but my responses have been wrong. Note that on page 150 he discusses the properties of the vector n. It needs to be either timelike, or null so that the string is spacelike. In order to define [itex]n\cdot X = X^-[/itex] as the light-cone gauge, he would be using [itex]n = (\frac{1}{\sqrt2}, \frac{-1}{\sqrt2}, 0, ...)[/itex] and this n is spacelike. I'm sorry for wasting your time in this speculation.
ehrenfest
#8
Oct12-07, 04:45 PM
P: 1,996
Quote Quote by jimmysnyder View Post
I'm confused? I thought both of the light-cone vectors were light-like i.e. null?
Jimmy Snyder
#9
Oct12-07, 04:53 PM
P: 2,179
I speak of the vector n, it must be timelike or null. I'm not sure what you mean by both of the light-cone vectors.
ehrenfest
#10
Oct12-07, 05:33 PM
P: 1,996
I was thinking that because the light-cone was the boundary between spacelike and time-like vectors, every vector on the light cone must be null.
Is that a contravariant expression for n? If you plug that into equation 2.8, it seems like it is null as well as the + version of n. Maybe thats not right though because equation 2.8 has deltas.
ehrenfest
#11
Oct19-07, 07:29 PM
P: 1,996
Can you show me explicitly why is is timelike or null and why the n for X^+ is spaceline?
ehrenfest
#12
Oct20-07, 12:23 PM
P: 1,996
I think it actually comes from even earlier in the book. On page 21, he says that "we will take x^+ to be the light-cone time coordinate" and he admits that this is completely arbitrary in the paragraph above.
Another weird thing, though. On page 27, he says "In light-cone coordinates, p_+ appears together with the light-cone time x^+"
I am not sure what "appears together" means?
Jimmy Snyder
#13
Oct20-07, 05:02 PM
P: 2,179
He means that in equation (2.85) the two are factors in the same term, just as [itex]p_0[/itex] and [itex]x^0[/itex] are in equation (2.84).
I think though, that you are confusing light-cone coordinates with the light-cone gauge. The first sentence in section 9.5 on page 160 says:
Quote Quote by Zwiebach
The light-cone solution of the equations of motion involves using light-cone coordinates to represent the motion of strings, and imposing a set of conditions that defines the light-cone gauge.
Later on the page he explains what 'selecting the light-cone gauge' means.
Register to reply
Related Discussions
Zwiebach string theory question Advanced Physics Homework 1
Introductory Interactive Online String Theory Seminar at the String Coffee Table Beyond the Standard Model 0
How does string field theory differ from string theory Beyond the Standard Model 17
