Register to reply
Multiple pulley problem
by jumptheair
Tags: multiple, pulley, solved
Share this thread:
jumptheair
#1
Oct12-07, 02:31 PM
P: 16
**Image of apparatus
http://www.learning.physics.dal.ca/l...ype09/neck.jpg
When a patient's injured neck is healing, it is often desirable to prevent the weight of the head from pushing down on the neck. This can be accomplished with the system of pulleys shown in the figure. The pulleys are small and light and have no appreciable friction. The rope about pulleys 1 and 3 make an angle of θ1 = θ2 = 26.0; pulleys 1 and 3 are constrained to move only in the vertical direction. Typically, a person's head makes up 7.00 % of the body weight. If the head of a 65.0 kg person is to be supported completely by the apparatus shown, what should the mass M of the weight W be?
2. Relevant equations
Fnet=ma
3. The attempt at a solution
I started with the head component and determined that pulley 1 and 3 are each responsible for maintaining half of the weight of the head of 44.59N. From then on, I do not know how to draw the FBD of neither pulley 1 or 3 as a system. I would appreciate any help that can hint me on figuring out the answer. Thanks.
Phys.Org News Partner Science news on Phys.org
Sapphire talk enlivens guesswork over iPhone 6
Geneticists offer clues to better rice, tomato crops
UConn makes 3-D copies of antique instrument parts
Astronuc
#2
Oct12-07, 08:17 PM
Admin
Astronuc's Avatar
P: 21,827
The weight W puts a tension in the line, and in a static situation T = W =Mg. With frictionless pulleys, the tension in the line must be the same along the length of the line.
Then either pulley 1 or 3 support half the head weight.
For either pulley, the tension pulls upward - one side vertically, and the other side at angle 26.0 from vertical.
Determine the tension T, necessary to support half the head, then M = T/g.
jumptheair
#3
Oct12-07, 08:33 PM
P: 16
Got it. Thanks!
Register to reply
Related Discussions
Multiple Pulley Power Transfer Mechanical Engineering 7
Pulley problem (Rotation) Introductory Physics Homework 2
Pulley/Torque problem where pulley has mass Introductory Physics Homework 4
Tension in Chain in Multiple Pulley Station Introductory Physics Homework 1
Question about a 2 mass, multiple pulley problem. Introductory Physics Homework 8
