Calculate Work to Pump Water out of Tank | Joules Required
  • Context: Undergrad
  • Thread starter Thread starter fubag
    Work
The discussion focuses on calculating the work required to pump water out of a conical tank using the principles of physics. The tank has a radius of 5 meters and a height of 10 meters, with water exiting a spout 2 meters above the tank. The volume of the cone is calculated as 250π/3 m³, and the work is derived from integrating the force needed to lift thin slices of water to the exit spout. The final formula for work involves integrating the expression W = ∫ (12-h) ρ g π (h²/4) dh from 0 to 10, where ρ is the density of water (1,000 kg/m³) and g is the acceleration due to gravity (9.8 m/s²).
  • Understanding of calculus, specifically integration techniques
  • Knowledge of fluid mechanics principles, including force and work calculations
  • Familiarity with the geometry of cones and volume calculations
  • Basic physics concepts such as density and gravitational force
  • Study integration techniques for calculating work done in physics problems
  • Learn about fluid dynamics and the principles governing fluid movement
  • Explore the geometry of conical shapes and their applications in real-world scenarios
  • Investigate the relationship between force, mass, and acceleration in various contexts
Students in physics or engineering, educators teaching fluid mechanics, and professionals involved in hydraulic systems or water resource management will benefit from this discussion.
fubag
Calculate the work (in joules) required to pump all of the water out of tank. Assume that the tank is full, distances are in meters, and the density of water is 1,000 kg/m^3.
The conical tank (pointing downwards) has water exiting a spout feet above the tank. Find the work down in removing the water. Radius of tank = 5 meters, height = 10 meters, and then spout is 2 meters above this.
Well, I am not sure how to start this.
How can I find the volume of a slice? I also noticed that we have enough information to just solve for the Volume of the cone = 1/3pir^2h= 250pi/3.
If Work = Force * distance.
Force = g*density*volume
so can I just plug it in here?
F = (9.8)(1000)(250pi/3)
And then distance it needs to travel is 12 feet? 10 to go to the top of the conical tank, and plus 2 to exit the spout?
I am not sure, any help will be deeply appreciated.
All of the water does not have to be moved from the bottom to 2 meters above the tank, this is only true for the water at the bottom of the pool. Instead, should write down the work needed to lift a thin slice of thickness ##dh## at a height ##h## over the bottom to the exit spout. The volume of this slice is given by
dV = \pi r(h)^2 dh,
where ##r(h) = h/2## is the radius of the tank at height ##h##. The work required to lift this to 2 meters above the pool is given by
dW = (12-h) \rho g dV
by the exact same physical reasoning you hinted at. Here, the ##12-h## is the height that the slice needs to be lifted. Integrating over all slices, you would obtain
W = \int dW = \int_0^{10} (12-h) \rho g \pi \frac{h^2}{4} dh.
Solving this integral and inserting the appropriate values for ##\rho## and ##g## will give you the correct answer.
  • · Replies 56 ·
