How Much Work Is Required to Lift a 25-ft Chain Up a Building?
The discussion focuses on calculating the work required to lift a 25-ft chain with a density of 4 lb/ft over the side of a building. Participants emphasize breaking the chain into N segments to estimate the work done on each segment and ultimately compute the limit as N approaches infinity using integral calculus. A key point raised is the need to use mass instead of volume when calculating the force, specifically noting that the mass of the chain segment is given by (25 ft * 4 lb/ft) / N.
  • Understanding of integral calculus
  • Familiarity with the concept of work in physics
  • Knowledge of density and mass calculations
  • Basic principles of force and motion
  • Study the fundamentals of integral calculus for applications in physics
  • Learn about the work-energy theorem in mechanics
  • Explore density and mass relationships in physical systems
  • Review examples of calculating work done in lifting objects
Students in physics, engineers involved in mechanical design, and anyone interested in understanding the principles of work and energy in lifting systems.
fubag
How much work is done lifting a 25-ft chain over the side of a building? Assume that the chain has a density of 4 lb/ft. Hint: Break up the chain into N segments, estimate the work performed on a segment, and compute the limit as N approaches infinity as an integral.
(The small segment of the chain of length delta y located y feet from the top is lefted through a vertical distance y.)
Force = g*density*volume...?
whats the volume of a segment of the chain, I am having difficulty.
please help
Volume is wrong here. It has to be mass: ##(25ft. \cdot \;4 lb./ft.)/N##.
14K
