Understanding Static Pressure: Causes of Pressure Changes in Air Flow
This discussion focuses on the relationship between air flow and static pressure changes in a variable cross-section tube. As the cross-section area increases, the average flow speed of air decreases, leading to an increase in static pressure, as explained by Bernoulli’s theorem. Conversely, when air speeds up in a narrower section of the tube, static pressure decreases. The conversation emphasizes the physical processes underlying these phenomena rather than solely the mathematical proofs of Bernoulli’s theorem.
  • Understanding of Bernoulli’s theorem
  • Familiarity with the continuity equation
  • Basic principles of fluid dynamics
  • Knowledge of variable cross-section flow systems
  • Research the implications of Bernoulli’s theorem in real-world applications
  • Explore the continuity equation in various fluid flow scenarios
  • Study the effects of turbulence on static pressure in airflow
  • Investigate the design of variable cross-section ducts for HVAC systems
Engineers, physicists, and students studying fluid dynamics, as well as professionals involved in HVAC system design and analysis.
leonpalios
When air flows through a variable cross - section tube, as the cross - section area increases, the average flow speed of air decreases (due to continuity equation) and according to Bernoulli’s theorem the static pressure increases. Regardless of the mathematical proof of Bernoulli’s theorem, what physical process causes the static pressure increase?
What physical process causes the static presssure decrease when the air speeds up passing through a narrow part of the tube?
See this thread.
  • · Replies 20 ·
  • · Replies 17 ·
  • · Replies 30 ·
