Thread Closed
On the uncertainty principle for photons. An experimental counter example??
Share Thread Thread Tools
Oct18-07, 05:00 AM   #1
From QM follows that the position of a photon can not be determined
better than L (de Broglie wavelength).
Suppose one creates a wave in the meter range - say L=2m. Could the
photons in this wave go through a tube of radius 1 cm?
If one registers a click of a photon counter placed inside the tube -
would this be a counterexample of QM - e.g. the position of the photon
determeined better than de Broglie's wavelength???
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> New X-ray method shows how frog embryos could help thwart disease
>> Bringing life into focus
Oct18-07, 05:00 AM   #2
Google
"near field" microscopy 107,000 hits
Subwavelength apertures are commonplace. Exit intensity rapidly
decays with conduit length.
Uncle Al
http://www.mazepath.com/uncleal/
(Toxic URL! Unsafe for children and most mammals)
http://www.mazepath.com/uncleal/lajos.htm#a2
Oct19-07, 05:00 AM   #3
> Uncle Alhttp://www.mazepath.com/uncleal/
> (Toxic URL! Unsafe for children and most mammals)http://www.mazepath.com/uncleal/lajos.htm#a2
So it's a counterexample which takes common place???
Regards: Kevin
Oct19-07, 05:00 AM   #4
If you think so, please show a derivation from first principles.
(and please, wavelength will do. No need to involve De Broglie)
Yes. Try it.
No, unless you supply the proof required.
You can do better than that though.
Suppose you throw a photon with sufficient energy
at an atom, and detect the resultant photo-electron.
If you see an electron you have fixed the position of the photon
to an atomic diameter, much smaller than its wavelength.
For further amusement you may note that the atom
can by a hydrogen atom in a Rydberg state,
which allows you to detect even radio-frquency waves.
Best,
Jan
Oct20-07, 12:36 AM   #5
The de Broglie wavelength is not the same as the uncertainty in the particle's position. To quickly convince yourself of this, plug the de Broglie wavelength into the uncertainty principle. You will see that this implies that the uncertainty in momentum has a lower bound, and that this lower bound increases as momentum increases. QM does not limit how precisely we can determine momementum, but rather, how precisely we can simultaneously determine momentum and position.
Oct20-07, 05:00 AM   #6
I think the misunderstanding is that QM does not say that the energy
of a photon cannot be captured in a volume much smaller than its
wavelength, but that the exact path that the photon travels between
source and detection cannot be measured more precisely than this. As
other replys have pointed out, the energy in a radio frequency photon
can originate from a volume with dimensions orders of magnitude
smaller than the wavelength, and when the photon is detected the
location of detection can be determined with much greater precision as
well. It is the location of the "photon" in between these two events
that is uncertain.
Rich L.
Oct21-07, 05:00 AM   #7
de Broglie wave length L = h/p
uncertainty (delta L) => h/(4pi(delta p))
There is a difference.
Richard
Oct22-07, 05:00 AM   #8
"Rich L." <ralivingston@sbcglobal.net> wrote in message
news:1192800026.682129.277410@i38g2000prf.googlegroups.com...
> that is uncertain.
> Rich L.
Sure, but what about the Delta x times Delta p >= hbar/2 problem? If the
position is momentarily at the size of an atom (a few tenths of nm) and much
smaller than wavelength, then the momentum uncertainty is more than the
wavelength - but it can't be. There must be a good answer, but is it simple?
Oct23-07, 05:01 AM   #9
On Oct 21, 6:58 am, Neil Bates <neil_del...@caloricmail.com> wrote:
> "Rich L." <ralivings...@sbcglobal.net> wrote in message
> > that is uncertain.
> > Rich L.
>- Hide quoted text -
That would be true for the photon, but once it is "detected" it
doesn't exist anymore. The energy of the photon is now in an electron
confined (possibly) to an atom. The uncertainty principle doesn't say
anything about what happens when the wave function "collapses" like
this.
Rich L.
Oct23-07, 05:01 AM   #10
The position-momentum uncertainty as you wrote it applies only to
Gaussian wave packets, you can't apply it to a plane wave (unless you
think it as a limit for Delta x -> infinity).
Anyway, if you light the atom with a radio frequency wave, and you get
a photo-electron, you know that you've hit it. Now, how do you know
where is the atom? The only information you have is that you've hit
it, but you don't know where you did it better than the wavelength.
If you want to pin down the position of the atom better than that, you
can start to use more spatially- (or time-) compressed wave packets,
and you will start to lose the energy information, just as the
uncertainty principle says. For example, if you want to know the
position within 0.1nm, you'll need a wave packet with an energy
dispersion of at least 1keV.
Regards,
Guillermo
Oct23-07, 05:01 AM   #11
> > that is uncertain.
> > Rich L.
this.
Rich L.
Oct23-07, 05:01 AM   #12
Regards,
Guillermo
Oct28-07, 05:00 AM   #13
"Richard Saam" <rdsaam@att.net> wrote in message
news:gSHRi.232966$ax1.37139@bgtnsc05-news.ops.worldnet.att.net...
> Richard
The Heisenberg uncertainty principle requires that when the uncertainty
in a photon's position is less than it's wavelength (lambda), the
uncertainty in its momentum must be greater than hc/lambda (ignoring
factors of 2 and pi). This is possible because the photon momentum is
complex, with both a real part, with magnitude hc/lambda, and an
imaginary part, which makes the total magnitude of the momentum greather
than hc/lambda.
The imaginary component of the momentum required for subwavelength
resolution corresponds to an attenuation of the photon wave. Using a
narrow tube to define the photon position comes at the cost of an
exponential loss of intensity.
Oct30-07, 05:00 AM   #14
Yes. Try it.
Best,
Jan
Sorry about the delay. A huge lack of Internet connection...
I think that was a trivial fact. Nevertheless the prove I found seems
a little strange to me too.
It's from QED of Beresteckii, Lifshitz (the intro).
It's like that:
1. Min uncertainty of x -> Dx for a massive particle in its rest frame
is Dx=h/mc (under h I mean Dirac's h not Heisenberg's h->h/2PI but I
dont know how to write it with this bar up.. - that's why ...... was
confused with this 4PI - ---- the second 2 is from some preciser
formulation of DxDp=h/2)
2. Min uncertainty in the frame where the particle is moving with
energy E is then Dx=ch/E
3. For ultrarelativistic particles E almost = cp hence Dx>h/p
4. Photons are always relativistic so Dx>h/p=L (lambda as introduced
by de Broglie).
In this book also stands the following.
The above is valid for experiments from every result of which x can be
determined (I would call this experiments of class I)
If one uses impacts without probability one for the time of experiment
from each deflection of the probe particle one can judge about x. But
if deflection is 0 one can not tell anything about x (class II).
I think my experiment is from class I and yours is from class II.
To Rich:
as
that is uncertain.
Rich L.
If there is a source of radiowaves and I put in front of it a tube of
lenght 10 m and r=2 cm with a detector at the end and the detector
clicks I could be absolute sure of the path and Dp wouldn't also be
great provided 'c' is a constant.
Oct31-07, 05:00 AM   #15
On Oct 29, 10:17 am, kvblake <kvblake2...@yahoo.com> wrote:
... cut text...
> To Rich:
> as
> that is uncertain.
> Rich L.
If you did this experiment, you would find that the probability of
detecting the radio frequency photon was extremely small, assuming the
walls of the tube are opaque to radio waves and the wavelength is much
greater than 2cm. This is no more mysterious than detecting a photon
in the evanescent region where the photon theoretically cannot exist
at all. The QM wave function exists in such areas, but is attenuating
rapidly with distance into it. QM makes experimentally confirmed
accurate predictions about such situations.
Rich L.
Nov2-07, 05:00 AM   #16
> .. cut text...
> > To Rich:
> > as
> > that is uncertain.
> > Rich L.
> Rich L.- -
Thanks for consideration:
I am sure that probability for detection would be extremely small. But
as you say there would be such detections even with opaque walls.
What about the path!!! of that photon (even the impulse) - if there is
just one exception the Heisenberg principle is threatened???
I can even remove a part of the tube and know the path of that photon
in between?!
Regards: Kevin
Nov2-07, 05:00 AM   #17
> > .. cut text...
> > > To Rich:
> > > as
> > > that is uncertain.
> > > Rich L.
> > Rich L.- -
> in between?!
> Regards: Kevin- Hide quoted text -
> - Show quoted text -
I don't think so. The Heisenberg principle concerns the product
delta_P*delta_X or delta_E*delta_T. In the case of the tube you are
confining in the X and Y directions to the diameter of the tube
(assuming it extends along the Z direction). Delta X and Delta Y are
thus very small. The Uncertainty principle says the uncertainty in
the momentum in the X and Y directions will thus be very large, which
is is due to the high k (wavenumber) in order to meet the boundary
conditions on the walls of the tube (the math is easier if you use a
square tube). Thus at the end of the tube you do indeed have a very
precise location for the photon, but you have a very poor idea of it's
momentum in the X and Y directions. In fact it is because the
momentum uncertainty is so large that the amplitude is decaying
exponentially down the tube.
Does that help?
Rich L.
Thread Closed
Thread Tools
Similar Threads for: On the uncertainty principle for photons. An experimental counter example??
Thread Forum Replies
uncertainty principle, relating the uncertainty in position to the uncertainty Advanced Physics Homework 3
Experimental distinction between states with one and two photons Quantum Physics 19
Experimental uncertainty Advanced Physics Homework 1
Experimental interference of independent photons Quantum Physics 3
uncertainty in heisenbergs uncertainty principle Quantum Physics 8
