Register to reply
Torque in a rotating rod
by aligass2004
Tags: torque
Share this thread:
aligass2004
#1
Oct18-07, 10:25 PM
P: 236
How much torque must the pin exert to keep the rod from rotating if the rod has a length L=65cm and a mass m=2.0kg? Calculate this torque about an axis that passes through the point where the pin enters the rod and is perpendicular to the plane of the figure.
http://i241.photobucket.com/albums/f.../p13-25alt.gif
2. Relevant equations
3. The attempt at a solution
I haven't attempted the problem because I'm not quite sure where to start. I know that you have to find Tnet, and I know the mass and the length fit into the equation somewhere. I'm just not sure how to set the equation up.
Phys.Org News Partner Science news on Phys.org
An interesting glimpse into how future state-of-the-art electronics might work
Tissue regeneration using anti-inflammatory nanomolecules
C2D2 fighting corrosion
learningphysics
#2
Oct19-07, 12:27 AM
HW Helper
P: 4,124
What is the total torque the rod and the 500g mass exert about the pin?
The pin needs to create a torque of the same magnitude but the opposite direction, to cancel the above torque...
aligass2004
#3
Oct19-07, 12:38 AM
P: 236
Is it Tnet = mL - w? The w represents the mass hanging.
learningphysics
#4
Oct19-07, 12:40 AM
HW Helper
P: 4,124
Quote Quote by aligass2004 View Post
that's the idea, but there are mistakes... weight acts at the center of mass... take clockwise as positive... counterclockwise as negative for signs...
try to fix the expression.
aligass2004
#5
Oct19-07, 12:44 AM
P: 236
So is it Tnet = W - mL?
learningphysics
#6
Oct19-07, 12:48 AM
HW Helper
P: 4,124
no. take it step by step. what is the torque due to the 0.500kg hanging mass? take clockwise positive counterclockwise negative...
use the definition of torque... what is the force? what is the distance?
aligass2004
#7
Oct19-07, 12:51 AM
P: 236
T = -Fr and I think the F is just the weight of the mass. In case you couldn't tell, torque and I don't get along well.
learningphysics
#8
Oct19-07, 12:55 AM
HW Helper
P: 4,124
:) that's ok.
yes, that's the definition you need... here gravity acts downward... so the rod would turn clockwise due to gravity...
so we use a +...
torque due to the 0.500kg = 0.500*9.8*L
try to find the torque due to the weight of the rod... it acts at L/2...
aligass2004
#9
Oct19-07, 12:59 AM
P: 236
The torque due to the weight of the rod would be T = (2kg)(9.8)(.325m) = 6.37
learningphysics
#10
Oct19-07, 01:01 AM
HW Helper
P: 4,124
exactly. you're getting along better already. :)
so the total torque is 0.500*9.8*0.65 + 6.37...
so that's a clockwise torque about the pin... so the pin needs to exert a counterclockwise torque of the same magnitude...
aligass2004
#11
Oct19-07, 01:06 AM
P: 236
Got it. T = 9.555. I think I need you to sit beside me during my exam in a couple weeks.....just for the torque problems.
learningphysics
#12
Oct19-07, 01:06 AM
HW Helper
P: 4,124
lol. nahh.. you won't need me.
jumbogala
#13
Feb24-10, 04:21 PM
P: 400
I am doing a very similar problem to this one. My question is, why do you have to pick the left end of the rod as your pivot point?
I tried using the center of mass and another point as pivot points and got different answers for the torque from the pin each time. How do you know which is the correct one?
Register to reply
Related Discussions
Woman standing on ball of foot - torque Introductory Physics Homework 4
Net Torque Introductory Physics Homework 6
Static equilibrium and torque Introductory Physics Homework 10
Torque of bolted beam Introductory Physics Homework 1
Help: TORQUE Introductory Physics Homework 1
