| Thread Closed |
Momentum and Impulse |
Share Thread | Thread Tools |
| Oct20-07, 10:16 AM | #1 |
A 55kg pole-vaulter falls from rest from a height of 5.0m onto a foam-rubber pad. The pole-vaulter comes to rest 0.3s after landing on the pad.
a) Calculate the athletes's velocity just before reaching the pad. b) Calculate the constant force exerted on the pole-vaulter due to the collition. Thanks!!! |
| Oct20-07, 10:41 AM | #2 |
Admin
We respectfully request that one show some effort and work with respect to the solution of the HW problem.
The pole vaulter decelerates constantly for 0.3s. Compare this with how long it took to fall 5.0 m. |
| Oct20-07, 10:50 AM | #3 |
O.K. So this is what I have done so far:
First we calculate the final velocity of the vaulter using kinematics: [tex] \[ \begin{gathered} \Delta x = v_i \Delta t - \frac{1} {2}g\Delta t^2 {\text{ when }}v_i = 0{\text{ we've got }} \hfill \\ \Delta x = - \frac{1} {2}g\Delta t^2 {\text{ and}} \hfill \\ \Delta t = \sqrt {\frac{{2\left( {{\text{5}}{\text{.0}}} \right)}} {g}} = 1.0{\text{s}} \hfill \\ {\text{Now we can find the final velocity using }}v_f = v_i - g\Delta t: \hfill \\ {\text{a) }}v_f = - 9.81\left( {1.0} \right) = - 9.81{\text{m/s}}{\text{.}} \hfill \\ {\text{b) }}F\Delta t = m\left( {v_f - v_i } \right) \Rightarrow F = \frac{{55\left( {0 + 9.81} \right)}} {{0.3}} = 1798{\text{N}}{\text{.}} \hfill \\ \hfill \\ {\text{But according to the back of the book both of them a wrong}}{\text{.}} \hfill \\ \end{gathered} \] [/tex] Thanks!!! PS: Sorry about that. |
| Oct20-07, 11:03 AM | #4 |
[tex]
\[ {\text{Got it }}v_f = \sqrt {2gh} \] [/tex] |
| Oct20-07, 11:05 AM | #5 |
depending on sig figs your velocity might be wrong.
also you could have gotten it faster using: [tex]v_f^2=v_i^2+2a\Delta x[/tex] you also switched the values in your formula for average force: [tex]F_{net}=\frac{m}{\Delta t}(v_f-v_i)[/tex] also your values for the final/initial velocity are wrong, you want final/initial velocity for the collision. -9.81 m/s will be your Initial velocity (because that is the speed at which the pole vaulter approaches the floor). You need final velocity, you know it takes .3s you know the acceleration it's experiencing so you can find the final velocity and plug that in. Edit: hm..actually I don't think you need to do this last part, you only need to do it when the object bounces back up. your signs are just wrong in your final answer. |
| Oct20-07, 11:11 AM | #6 |
sig figs issues
![]() Thank you!!! |
| Oct20-07, 01:48 PM | #7 |
Admin
Slowing down is faster. Starting at v, the mass slows over [itex]\Delta{t}[/itex] for an average acceleration (or deceleration) of a = [itex]\Delta{v}[/itex]/[itex]\Delta{t}[/itex] = v/[itex]\Delta{t}[/itex]. Please refer to http://hyperphysics.phy-astr.gsu.edu/hbase/mot.html and also http://hyperphysics.phy-astr.gsu.edu/hbase/traj.html |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Momentum and Impulse
| Impulse momentum | Introductory Physics Homework | 1 | ||
| Momentum, Impulse and consevation of momentum? | Calculus & Beyond Homework | 1 | ||
| Impulse and Momentum | Introductory Physics Homework | 29 | ||
| Impulse and momentum | Introductory Physics Homework | 1 | ||
| Impulse/Momentum | Introductory Physics Homework | 1 | ||
