The discussion explores the behavior of electrons in a long wire subjected to rapid voltage changes, particularly focusing on the propagation of electromagnetic fields and the resulting current flow. It considers both theoretical implications and practical scenarios, including the effects of wire length and configuration.
- Exploratory
- Technical explanation
- Conceptual clarification
- One participant questions the net current in a long wire when alternating voltages are applied at either end, suggesting a potential for zero net current due to the propagation delay of electromagnetic fields.
- Another participant explains that the change in the electromagnetic field will take time to propagate through the wire, indicating that no current flows until this change has reached the other end.
- A follow-up question arises about whether the electromagnetic field would "cancel out" under these conditions.
- It is proposed that continually changing potentials at each end of the wire would create waves propagating in both directions, with complex potential changes occurring throughout the wire.
- A participant suggests that curling the wire into a solenoid could lead to oscillating fields within, influenced by the changing electromagnetic waves.
- Another participant notes the difficulty in analyzing such scenarios, emphasizing that uniform current flow assumptions break down in extremely long wires due to propagation delays.
- A final inquiry considers whether similar effects could be achieved with shorter wires or coils through very rapid voltage changes, questioning the feasibility of such experiments.
Participants express various viewpoints on the behavior of electrons and current flow in long wires, with no consensus reached on the implications of rapidly changing voltages or the feasibility of similar effects in shorter wires.
The discussion highlights limitations related to assumptions about uniform electric fields and current flow in long wires, as well as the complexities introduced by rapid voltage changes.
