Group of symmetries on a regular polygon
by SiddharthM
Tags: polygon, regular, symmetries
SiddharthM
SiddharthM is offline
#1
Oct26-07, 12:29 PM
P: 176
So i began reading up on some group theory and I came across an interesting question, what is the order of the group of symmetries on of a n-sided regular polygon?
with a square it's 8, triangle it's 4.
I feel like i'm missing something with the pentagon cuz i'm only finding these:
the 5 rotations, two diagonal reflections which are NOT the same as that for the square, reflection over the vertical axis.
i'd appreciate any casual discussion on the topic as I find it fascinating,
at the very beginning because symmetries behave very much like permutations (if we label vertices) I thought there might be a relationship between this set and the symmetric group of {1,...n}? But there are obviously permutations that no movement of a polygon in the plane can mimic.
true or false: the group of symmetries of a n-sided regular polygon in the plane is isomorphic to a subset of the symmetric group of {1,...,n}.
cheerio!
Phys.Org News Partner Science news on Phys.org
Cougars' diverse diet helped them survive the Pleistocene mass extinction
Cyber risks can cause disruption on scale of 2008 crisis, study says
Mantis shrimp stronger than airplanes
d_leet
d_leet is offline
#2
Oct26-07, 01:43 PM
P: 1,076
There are more than 4 for a triangle. I'm also not sure how you can compare the diagonal reflections of a pentagon with those of a square, but there are more than 2.
Look at the triangle again, and try to find all of it's symmetries (label the vertices with 1,2,3, and see f that helps you find more) then try to make an inference as to the general order of this group based on your findings for the triangle and the square.
SiddharthM
#3
Oct26-07, 01:59 PM
P: 176
there are two more for the triangle - with the base of the triangle on a horizontal axis we can switch the top vertices with the right vertices by flipping the triangle from the left vertices and vice versa with if you flip the triangle from the right vertices.
2n?
AlphaNumeric2
AlphaNumeric2 is offline
#4
Oct26-07, 07:50 PM
P: 40
http://en.wikipedia.org/wiki/Dihedral_group should be of use to you. In direct response to your question, the page notes that for small n, the Dihedral group isn't a subgroup of the symmetric group S_n, as demonstrated by the fact n! < 2n for n=1.
Kummer
Kummer is offline
#5
Oct26-07, 09:29 PM
P: 291
Here is how to think of it.
1)Draw a regular polygon with vertices 1,2,...,n in order.
2)The question is how many ways can the polygon be replaced by rigid motions, i.e. with vertices still in order. Now for any one of the n locatations there are n choices. Having chosen that there is only one chose for the next one in succession, i.e. either left or right. Having chosen that the polygon is completely determined. Thus there are 2n elements in this group.
3)Let a be the positive rotation by 2pi/n i.e. the cycle (1,2,...,n) and let b be the reflection through the middle and vertex 1, i.e. (2,n)(3,n-1).....
4)So a^n = 1 and b^2 = 1.
5)Consider S = {a^k,ab^k} for k=1,2,...,n
6)There are 2n elements in that set all of which are distinct. So S represents the group D_n.
7)Now it remains to show ba=a^{n-1}b which is not so hard to show.
Hence the group presentation for the dihedral group is:
[tex]\left< a,b| a^n = 1, \ b^2 = 1, \ ba=a^{n-1}b \right>[/tex]
Register to reply
Related Discussions
regular and non-regular magic squares Calculus & Beyond Homework 0
Conformal map for regular polygon in circle. Calculus 1
Archived thread "Volumes of Regular Icosahedron and Regular Tetrahedron" General Math 0
Volumes of Regular Icosahedron and Regular Tetrahedron General Math 20
