Register to reply
Hooke's Law / Potential Energy
by twotaileddemon
Tags: energy, hooke, potential
Share this thread:
twotaileddemon
#1
Oct26-07, 08:58 PM
P: 263
A daredevil plans to bungee jump from a balloon 65.0 m above a carnival midway. He will use a uniform elastic cord, tied to a harness around his body, to stop his fall at a point 10.0 m above the ground. Model his body as a particle and the cord as having negligible mass and obeying Hooke's law. In a preliminary test, hanging at rest from a 5.00 m length of the cord, he finds that his body weight stretches it by 1.50 m. He will drop from rest at the point where the top end of a longer section of the cord is attached to the stationary balloon.
(a) What length of cord should he use?
(b) What maximum acceleration will he experience?
2. Relevant equations
F_cord = -kx
F_gravity = mg
U_cord = .5kx^2
U_body = mgh
3. The attempt at a solution
Uh.. well, I searched the forum and someone had asked a strikingly similar question. From what I read, I should find k by setting the F_gravity to the F_cord, so mg = -kx
In that case.. k would be -mg/x
Then, the potential energy lost from traveling from 65 m to 10 m should equal the potential energy of the cord at 10 m. Thus,
mgh_f-mgh_i=.5kx^2
mgh_f-mgh_i = .5(-mg/x)x^2
h_f-h_i = -.5x
-55 = -.5x
110 = x
... but that would be the length the cord stretched... right? And that would be... the farthest distance it could cover.. Then, the length of the cord would be 110 m?
Then.. to find the max acceleration, ... I'm quite confused. I know the only forces acting on the person is due to gravity and that in the spring.. but what acceleration is there?
Thanks for any help
Phys.Org News Partner Science news on Phys.org
Experts defend operational earthquake forecasting, counter critiques
EU urged to convert TV frequencies to mobile broadband
Sierra Nevada freshwater runoff could drop 26 percent by 2100
Astronuc
#2
Oct26-07, 10:00 PM
Admin
Astronuc's Avatar
P: 21,885
The balloon is at 65 m, so the length of the cord must not be 110 m or the jumper goes splat.
OK, think about the problem.
Falling from 65 m to stop at 10 m, the jumper plans to fall 55 m.
The jumper will 'free-fall' a distance x, the length of the cord, before it starts stretching, so the jumper has kinetic energy = mgx at this point. Then the jumper must decelerate to stop at 10 m from the ground or total distance of 55 m.
The jumper then recoils, subject to a force F = kd, where d is the extension of the cord from equilibrium, and k is the spring constant.
Determine the spring constant from this.
twotaileddemon
#3
Oct26-07, 10:12 PM
P: 263
Quote Quote by Astronuc View Post
How? We have no force variable given
I know that F = -kx, and U = 1/2kx^2.. but...
Astronuc
#4
Oct26-07, 10:23 PM
Admin
Astronuc's Avatar
P: 21,885
Quote Quote by twotaileddemon View Post
What is weight? If k is in terms of m, the do what one did with
mgh_f-mgh_i=.5kx^2
twotaileddemon
#5
Oct26-07, 10:31 PM
P: 263
mgh_f = mgh_i = .5kx^2
k = 2mgh/x^2...?
twotaileddemon
#6
Oct26-07, 10:39 PM
P: 263
the weight should just be.. mg?
so mg = kx?
k = mg/x
Astronuc
#7
Oct26-07, 10:44 PM
Admin
Astronuc's Avatar
P: 21,885
so mg = kx?
k = mg/x
Be careful there, the x needs to be the displacement of the spring/cord.
The 5 m length stetches 1.5 m, so k(1.5m) = mg.
twotaileddemon
#8
Oct26-07, 10:49 PM
P: 263
using k = mg/1.5 then...
mg(hf-hi) = .5kx^2
mg(hf_hi) = .5(mg/1.5)x^2
h = .5x^2/1.5
3(55) = x^2
x = 12.84 m.. which still doesn't make sense, because the length shold be much greater
Astronuc
#9
Oct27-07, 11:42 AM
Admin
Astronuc's Avatar
P: 21,885
Try writing the energy balance equation.
Assuming no dissipative forces, the energy in the spring must equal the GPE of the free fall (which equals the kinetic energy of the jumper before the cord stretches) and the work done by the cord when it stretches.
Now the cord has length L which one is trying to find, so the jumper freefalls this length (height). Then the cord stretches, some length d, and decelerates the jumper to a stop (v=0). BUT, since the stretched cord must stop at 10 m, and the jumper started at 65 m, the stretched core must have length 55 m, so the displacement d of the core must be 55-L.
See where that takes one.
Think about an elevator slowing down. Think of g+a.
Register to reply
Related Discussions
Inconsistent calculations with Hooke's Law/Elastic Potential Energy Introductory Physics Homework 6
Challenging physics question, hooke's law and conservation of energy Introductory Physics Homework 1
Print ViewElectric Potential Energy versus Electric Potential Introductory Physics Homework 2
Electric potential, potential difference, and potential energy Introductory Physics Homework 2
Potential energy of a spring,POTENTIAL ENERGY OF LOADING Classical Physics 3
