Rank Bulbs A-F: Brightest to Dimmest
The discussion revolves around ranking the brightness of six identical bulbs connected to an ideal battery. Participants are tasked with determining the order of brightness from bulbs A to F based on their electrical characteristics.
  • Participants are exploring how to calculate the currents in each bulb in relation to their resistances. There is a suggestion to analyze the circuit configurations and consider the effects of one bulb on another, particularly bulbs C and E together.
The discussion is ongoing, with some participants providing hints and guidance on how to approach the problem. There is an emphasis on the need for the original poster to demonstrate their thought process and attempts before further assistance can be offered.
There is a mention of potential assumptions regarding the behavior of the bulbs, specifically whether they can be treated as ideal resistors. The original poster has not yet provided their initial attempts or reasoning.
skli
The figure shows six identical bulbs connected to an ideal battery. All the bulbs are glowing
Please see attached file.
Rank in order, from brightest to dimmest, the brightness of bulbs A to F.
Thank you
copy from Physics for Scientists and Engineering with Modern Physics by Randall D. Knight.
show ur attempt.
or, are you trying to check us??
OK - you get a little hint:
You need to figure the currents in each bulb, not in amps, but in terms of bulb resistances.
The current in D is going to be affected by everything that goes on with B, C, E, F.
Before you can get that right, realize you need to figure what C and E look like taken together.
You have a formula for resistors in series and in parallel. Figure out some alternative diagrams with new resistances representing the combinations of bulbs. Look at the branches, and figure that a current arriving has to split, being shared between the resistances with the most share going to the arms with the lower resistances in inverse proportion
Start off by thinking about bulb A compared to bulb D. Come back with what you have.
Just a side note: light bulbs have negative resistance and hysteresis. If your teacher did not specify, my guess would be that you are to assume the bulbs act just like resistors.
We do need some evidence that you have tried to solve the problem, or at least some questions from you that indicate you are thinking about it, before we can help much more than by giving you the theory.
9K
56K
