Limitation of metallic sharpness from local electric field
The discussion centers on the limitations of metallic sharpness due to local electric fields, specifically addressing the sharpness of zero-dimensional needle points and one-dimensional razor edges. It establishes that the sharpest point achievable is a single atom, which can be realized using atomic force microprobes (AFMs). IBM scientists have conducted significant research in this area, highlighting the relationship between material properties, geometry, and electric field concentration in determining sharpness limits. The conversation emphasizes that sharpness is constrained not only by atomic structure but also by factors such as spontaneous fracture at the tips of metallic tools.
  • Understanding of atomic force microscopy (AFM) principles
  • Familiarity with electric field effects on materials
  • Knowledge of material properties related to sharpness
  • Basic concepts of geometry in tool design
  • Research atomic force microscopy (AFM) techniques and applications
  • Explore the relationship between electric fields and material sharpness
  • Investigate the effects of geometry on the performance of cutting tools
  • Study the phenomenon of spontaneous fracture in metallic tips
Materials scientists, mechanical engineers, and anyone involved in the design and optimization of cutting tools and sharp instruments.
Loren Booda
Since there is a significantly-above atomic limit to the allowed sharpness of an (approximately zero-dimensional) needle point due to its local electric field, would there be a similar limit to the keenness of an (approximately one-dimensional) razor edge?
The limitations are related to materials and the geometry of tools used to make needles and razors.
The sharpest point would be a single atom, and this is only achieveable with atomic force microprobes. IBM scientists have done some amazing work with AFMs.
http://adsabs.harvard.edu/abs/1992SPIE.1556...79N
More generally -
http://www.iop.org/EJ/abstract/0960-1317/2/3/026
http://www.freepatentsonline.com/5611942.html
Unfortunately, I can't find a general paper or site that gives details on AFM's.
Astronuc,
By "sharpness" I mean in terms of slimness, as in least solid angle for a needle. The probes you mention (granting the terminal atoms) are rather blunt nonetheless. My E-M professor once mentioned that the sharpness of metallic "spline" was limited (somewhat related to the effect of a lightning rod or comb teeth on a van de Graaff generator) by spontaneous fracture of its tip. So a needle, or spline, could only be so pointed, not from atomic considerations so much, but from the concentration of electric field in its above atomic scale tine.
  • · Replies 73 ·
19K
