Thread Closed
Special Theory of Relativity
Share Thread
Oct31-07, 09:36 AM   #1
Thanks for taking a look. The following question is that is that from a grade 12 academic physics course.
Scientist Ludwig von Drake, while in his laboratory, measures the half-life of some radioactive material which is in a bomb, approaching with speed v. Donald Duck, who is riding on the bomb, also measures the half-life. His answer is a factor of 2 smaller than Ludwig's. What is the value of v, expressed as a fraction of c?
Answer: .87
2. Relevant equations
Special relativity equation: t=t0/square root (1-v2/c2) Note: 2 = squared
Other: I know there is at least one more I must use but for the life of me don't know what it is.
3. The attempt at a solution
First we set V=Drakes. If this is so than Donald's equation must be equal to:
t=[t0/square root (1-v2/c2)]/2
Therefore to= 2t[square root (1-v2/c2)]
The problem is in equating the equations. They end up cancelling out because one is a direct derivative of the other. This leads me to believe I need at least 1 more equation.
It must also be noted that while von Drake may use the special equation of relativity Donald duck cannot (at least this is what I figure). I say this because Donald duck is viewing the half-life from the bomb at rest, meaning he would be more in the realm of inertial frame of reference. What equation i now use knowing that I have no idea.
Thanks in Advance guys.
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Oct31-07, 12:42 PM   #2
Recognitions:
Homework Helper Homework Help
t=t0/square root (1-v2/c2) (this is the time dilation formula)
t is Drake's time
t0 is the proper time which is Donald's time.
we are given that t = 2t0.
so you have equations:
t = 2t0
so solve these 2 equations.
Oct31-07, 08:11 PM   #3
Donal Duck is measuring the proper time interval [tex]t_0[/tex], so the interval measured by Drake is [tex]t=t_o\lambda[/tex]. We're given that [tex]t=2t_o[/tex]. Dividing both equations we get that [tex]\lambda=(1-\frac{v^2}{c^2})^{-1/2}=2[/tex]. Solving the equation yields the solution.
Nov1-07, 09:02 PM   #4
Thanks guys. My solution set is similar to both of yours.
I used 2T= To/sqreroot(1-v2/c2) and 2T = To/x where x=.5
This yields sqreroot(1-v2/c2) = .5
Through squaring both sides and moving the variables/numbers around you obtain
.75c2=v2
Simply square root that to get the answer which is .866c=v
Once again thanks for your help!
Thread Closed
Similar discussions for: Special Theory of Relativity
Thread Forum Replies
Special Theory of Relativity Advanced Physics Homework 4
=Special Theory Of Relativity= Special & General Relativity 40
Relativity : the Special and General Theory Special & General Relativity 3
Einstein's theory of Special Relativity Special & General Relativity 8
Is The Theory Of Special Relativity Wrong? General Physics 18
