Could someone me with a question about gravity?
  • Thread starter mufcdiver
  • Tags
    Gravity
In summary, at the gravitational midway point between two or more massive objects, there is a point of equilirium that is unstable and can theoretically allow for a smaller object to orbit around "nothing" in a plane between the two large masses. This is known as the L1 equilibrium point and it is one of five equilibrium points in the restricted circular three body problem. However, maintaining this position would require a lot of fuel and a better alternative is to orbit around the L1 point. There could potentially be an L1 point at the center of the Milky Way, but it would be much closer to the Sun than the center of the galaxy.
mufcdiver
Hi, I'm new here and was wondering if anyone could tell me what exactly happens at the gravitational midway point between two(or more) massive objects. I imagine that if a much smaller object is there then it will be suspended there until a bigger force knocks it out of there, but if there are more that two massive objects and the knock out force is just right, would it be possible for the smaller object to orbit the afore mentioned midway point even though there is nothing physically there?
Quick Thoughts:
Considering two equal masses and a small test mass midway between these, then yes, there will be a point of unstable-equlibrium. In a real situation, any minor deviation from this point would cause the test mass to move to the nearest large mass.
There will be a plane between the two large masses whereby theoretically the test mass could make an orbit in this plane at right angles to the axis joining the two large masses. I.e It would orbit around 'nothing'. It would be unstable and would work mathematically. In reality any minor disturbance would make the test mass move to either of the large masses.
This orbit can be imagined as if you put the test mass midway between the two large masses and to one side of the central axis, it wolud experience a resultant restoring force directed towards the mid-point. Hence , given a push tangentially, it should orbit in this plane.
For two unequal large masses, there would be an unstable equilibrium point between them that is nearer to the smaller mass, but off-hand I don't think the test mass could make an orbit as above as there would be no plane at right angles in this situation.
For more than two large masses, then there can still be one equilirium point for the test mass. As long as one of the masses is physically so large as to make the equilibrium point inside the large mass or indeed the arrangement makes it so the equilibrium point is inside any particular large mass.
It should still work fine. I think the plane might be more accurately described as a very shallow hyperbolic plane.
All of you are treating this problem statically, and that is something you should not be doing. The two massive objects will attract each other gravitational as well as attracting the test mass. Each of the massive objects will be in some orbit about each other (and about their center of mass). Ignoring this motion leads to an incorrect identification of the equilibrium point. For example, the point at which space is gravitationally flat is not an equilibrium point unless the two massive bodies have the same mass. An unstable equilibrium point between the two massive bodies does exist, but it is not at the point where space is gravitationally flat.
This problem in general is called the three body problem. The problem becomes more tractable if the gravitational attraction induced by the test mass can be ignored (i.e., a non-massive test mass); this is the restricted three body problem. The special case of the massive bodies being in a circular orbit is called the restricted circular three body problem. Five equilibrium points exist for the restricted circular three body problem, one of which lies between the two massive bodies. This is the L1 equilibrium point. An inertial observer will see the L1 point as being in a circular orbit about the system center of mass. An observer in a rotating frame based on the two massive bodies will see all five LaGrange points as having fixed locations.
A satellite at the Sun-Earth L1 point would have unrestricted viewing of the Sun. However, the L1 point is an unstable equilibrium point. A spacecraft positioned at the Sun-Earth L1 point would have to expend a lot of fuel to maintain that position. A better alternative is to "orbit" the L1 point. Such orbits are still unstable, but not nearly so bad as trying to stay exactly at the L1 point. This is exactly the strategy used for the SOHO satellite, which is in a halo orbit about the Sun-Earth L1 point.
Thanks for the help guys.
Is there one of these points at the [gravitational] center of the Milky Way?
The L1 point for two bodies orbiting each orbit is closer to the smaller object than the larger object. For example, the Sun-Earth L1 point is quite close to the Earth: 1% of the distance from the Earth to the Sun, or about four times the distance from the Earth than is the Moon.
There would be corresponding LaGrange points for the Milky Way and Sun if all of the mass in the galaxy except our solar system were concentrated in the center of the galaxy. The Milky Way-Sun L1 point would be quite close to the Sun compared to the distance between the Sun and the center of the galaxy. It would not be anywhere near the center of the galaxy.
Hmm. Ever watched a ball in a wind tunnel at the science fair?
The simple answer is yes.
In a two body system a lateral thrust (say at right angles to the two bodies in question) that is not sufficient to reach escape velocity will eventually after the oscillation calms down translate into torque on the small body that would result in it returning to the balance point with spin that accounts for the conservation of angular and linear momentum. In a three, or multibody system if the thrust is just right (planar is easier to visulize, but not a requirement) it is possible if the masses create a locus of equipotential gradient that a small central mass is perturbed it will settle into some orbit around the centre of potential along the gradient well proporortional to its mass relative to the base masses and the distance from the theoretical centre and the velocity of orbit and the amount of energy translated into spin of the small object. See the previous posters links and some research on momentum.
Nothing is as odd as the truth.
1. What is gravity?
Gravity is a natural phenomenon by which all objects with mass are brought towards one another. It is a fundamental force that is responsible for keeping the planets in orbit around the sun and for the formation of galaxies.
2. How does gravity work?
Gravity is caused by the curvature of space and time around massive objects. The more massive an object is, the more it curves the space around it, creating a gravitational pull that attracts other objects towards it.
3. What is the formula for calculating gravity?
The formula for calculating gravity is F = G * (m1 * m2 / r^2), where F is the force of gravity, G is the gravitational constant, m1 and m2 are the masses of the two objects, and r is the distance between them.
4. How does gravity differ on different planets?
The force of gravity differs on different planets due to their varying masses and sizes. The larger the planet, the greater the force of gravity. For example, the force of gravity on Earth is stronger than on the moon because Earth is more massive and has a larger radius.
5. Can gravity be canceled or reversed?
Gravity cannot be canceled or reversed, as it is a fundamental force of nature. However, it can be counteracted by other forces, such as the centrifugal force of a rotating object or the electromagnetic force between two objects.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
