Determining Velocity with Projectile Motion
The problem involves projectile motion, specifically determining the velocity of an arrow launched at an angle that hits a balloon positioned 150m away and 100m above the launch point. The original poster has calculated the angles for the launch but is seeking assistance with finding the velocity at the moment of impact.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the use of vertical displacement to calculate vertical velocity (Vy) and confirm that horizontal velocity (Vx) remains constant. Questions arise about using specific kinematic equations to find final velocities at a given height.
Guidance has been provided regarding the use of kinematic equations to find the vertical component of velocity at the balloon's height. Participants are exploring different approaches to calculate the final velocity, with acknowledgment that two possible vertical velocities may exist at that height.
The original poster has provided specific values for initial velocity, horizontal distance, and vertical height, but the discussion reflects uncertainty about the next steps in the calculations and the implications of multiple solutions.
TexasCow
Ok I am having slight trouble with a homework problem. An arrow was launched at an angle, and hit a balloon that was 150m away and 100m up. I used my distance equations along with initial velocity to calculate the two angles that can be used to hit the balloon, but I'm stuck on the next part. I used t=dx/vx to solve for time, and now I need to solve for the velocity when the arrow hits the balloon. I'm sure it's a simple problem but I'm stuck!
Initial Velocity=60m/s
Distance from 0=150m
Height in Y direction=100m
dy=Voy(t)-4.9t^2
Vx=Vcos(x)
Vy=Vsin(x)
t=dx/vx
I used the four equations above to solve for the angle(s). Then put in the velocities to solve for time. How do I solve for velocity when the arrow hits the balloon?
You know vertical displacement, you can calculate Vy. Vx will remain constant.
Should I use Vy=Voy+at?
Yes, if you know V0y and t, you can use that to solve for Vy. You already know that Vx= V0x.
Yes, I know that Vx is constant throughout the motion. So using Vy=Voy+at, I can solve for the velocity at anyone point in time at a certain height?
You are given height, acceleration due to gravity, and initial Vy. Think of some other s-u-v-a-t formula which could give you final Vy at a given height more quickly!
P.S.:
1. You will get two Vy at a particular heght.. I hope you can decide which one to take!
2. From Vy thus obtained and Vx, you can, of course, obtain final velocity.
