| Thread Closed |
A Coil in a uniform magnetic field. Induced emf. |
Share Thread | Thread Tools |
| Nov4-07, 01:52 PM | #1 |
A 100 turn, 2.0 cm diameter coil is at rest in a horizontal plane.. A uniform magnetic field 60 degrees away from vertical increases from .50 T to 1.50 T in .60 s. What is the induce emf in the coil.
Mostly the problem I have with this one is determining the angle btw the B-Field and the plane of the area. I believe the area plane should be pointing to the left. in which case in the equation for flux it would be the cos(30). Just double checking though. Here is my diagram <http://img159.imageshack.us/img159/7747/areaplanebi6.jpg> |
| Thread Closed |
| Thread Tools | |
Similar Threads for: A Coil in a uniform magnetic field. Induced emf.
| A coil with turns given magnetic field, time find the emf induced in the coil | Introductory Physics Homework | 4 | ||
| positron movement in a coil-induced magnetic field | Introductory Physics Homework | 4 | ||
| Magnetic field through coil is given by mu*Current/2PI*r, right? | Introductory Physics Homework | 0 | ||
| Magnetic Flux and Induced EMF in a Coil | Introductory Physics Homework | 6 | ||
| magnetic field due to an elliptical coil | Advanced Physics Homework | 3 | ||
