Find mass of uniform solid disk?
The discussion centers on calculating the mass of a uniform solid disk designed as an industrial turntable with a diameter of 48.0 cm and a kinetic energy of 0.300 J at 31.0 rpm. The moment of inertia (I) for the turntable is established as 5.71×10^-2 kg m². The correct formula to determine the mass (m) is derived from I = 1/2 mr², leading to the conclusion that mass can be calculated using the relationship m = 2I/r², where r is the radius of the disk.
  • Understanding of rotational dynamics
  • Familiarity with the moment of inertia concepts
  • Knowledge of kinetic energy in rotational motion
  • Ability to manipulate algebraic equations
  • Study the derivation of the moment of inertia for various shapes, particularly solid disks
  • Learn about the relationship between kinetic energy and rotational motion
  • Explore practical applications of turntables in industrial settings
  • Investigate the effects of varying diameters on the mass and inertia of rotating objects
Mechanical engineers, physics students, and professionals involved in the design of rotating machinery or industrial equipment.
saturn67
you need to design an industrial turntable that is 48.0 cm in diameter and has a kinetic energy of 0.300 J when turning at 31.0 rpm
i found that inertia of the turntable about the rotation axis
is = 5.71×10^-2 kg m^2
If your workshop makes this turntable in the shape of a uniform solid disk, what must be its mass?
it try to use I=mr^2
so mass = I/r^2
but that don't work
Woot it work thank you
  • · Replies 19 ·
  • · Replies 19 ·
  • · Replies 27 ·
