A/C, are the british different?
  • Thread starter Thread starter tc_kid
The discussion revolves around the differences in alternating current (AC) wiring systems, particularly comparing British standards to those in other regions, such as the US and Singapore. Participants explore the configuration of live, neutral, and ground wires in AC systems, touching on historical context and safety considerations.
  • One participant expresses confusion about the British AC system, stating that they have always understood it to have two alternating live wires and a neutral/ground wire, contrasting this with what they are being taught in the British education system.
  • Another participant clarifies that in the British system, one live wire is referenced to ground, and the third wire is a safety ground that should not carry current under normal conditions.
  • A participant from the US explains the single-phase AC system there, noting that it consists of two 115V legs and a ground, with a center-tapped transformer providing a neutral reference.
  • A participant inquires about the AC system in Singapore and suggests that the grounding and neutral wires might be interchangeable, while also recognizing the redundancy of having both for safety purposes.
  • Concerns are raised about the efficiency of the British system, with one participant suggesting that it seems to waste more wire compared to having two legs as in other systems.
  • Another participant describes the wiring of streets with three phases and mentions that the neutral is grounded at the transformer, noting potential differences in voltage between the ground and neutral at the house depending on load balance.
Participants express differing views on the configuration and efficiency of AC wiring systems, with no consensus reached on the superiority of one system over another. The discussion remains unresolved regarding the implications of these differences.
Participants reference historical changes in wiring standards and safety measures, but the discussion does not resolve the technical details or assumptions underlying the different systems.
tc_kid
I'm abit confused, I've been dealing with electricity for ages and I've always understood alternating current to have 2 altenating live wires and a third neutral/ground wire.
Now I am in the british education system and they are teaching us that alternating current only has one live wire and two neutral wires, only one of which is grounded (this makes no sense to me)
when i look at the basic diagram of a generator i see no way how either of the usual 2 live wires could possibly be neutral unless they ground one of the two, in which case i don't see the use of another neutral/ground wire.
Well yes you are right.
That is exactly what they do, reference one of the output lines to ground. As a matter of history, until recently they used only the two wires. The "live" wire and "neutral" referenced to ground.
The third wire "ground" is a recent addition as a matter of safety and does not carry and should not carry any current except when something goes wrong.
"...ive always understood alternating current to have 2 altenating live wires and a third neutral/ground wire."
Don't get confused about the 230VAC that is coming into you home here in the US. It's single phase but you get two 115V legs and a ground (three wires). At the pole the transformer has a 230volt secondary that is center-taped to ground. Now at the breaker panel, each leg will have a neutral(return for leg) and ground(safety;just in case return) associated with it.
ok, well id like to figure out what we are on here in singapore, ill go grab a multimeter and figure it out...
if one of the outputs has been grounded so as to act as a neutral then either that or the ground wire should be interchangeable by right but i do see the purpose of having both now(incase one fails) so basically what i understand about the british mains so far is that there are 2 ground wires, one is a fail-safe. correct?
i must say though, the 2 legs seem to make a lot more sense to me... the british way seems to just waste more wire...
wasting wire connecting one secondary output to the ground that is...
The way streets are wired is that 3 phases go along the street and each house is supplied from one phase. Phase to neutral voltage is nominally 230V (used to be 240V).
The distribution transformer is a Y with the neutral grounded at the transformer.
The ground at the house may be at a different potential to the neutral wire depending on how well the load is balanced.
  • · Replies 83 ·
  • · Replies 32 ·
  • · Replies 18 ·
12K
  • · Replies 16 ·
  • · Replies 26 ·
