How Does a Bent Wire Affect the Magnetic Field at a Point?
  • Thread starter Thread starter EvanQ
    Current Wire
The discussion revolves around the magnetic field produced by a bent wire carrying a current. The original poster presents a scenario involving two segments of wire, each contributing to the magnetic field at a specific point, and seeks to understand how to calculate this field given the geometry and current involved.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore the application of the magnetic field equations, questioning the relevance of certain parameters such as the distance from the bend and the angle involved. There is also uncertainty about the correct equations to use and the meaning of specific variables.
Some participants have provided equations and attempted calculations, while others express confusion about the variables and their meanings. The discussion reflects a mix of attempts to clarify concepts and explore the mathematical relationships involved without reaching a consensus on the approach.
Participants note the specific parameters of the problem, such as the current, the dimensions of the wire segments, and the angles involved, while also highlighting areas of uncertainty, particularly regarding the definitions and roles of certain variables in the equations.
EvanQ
A wire carrying a 27.0A current bends through a right angle. Consider two 2.00mm segments of wire, each 3.00cm from the bend.
Find the magnitude of the magnetic field these two segments produce at point P, which is midway between them.
F = IL x B
B = F / IL
= F / 27 x 0.004 m (both 2mm segments combined)
once again stuck on how to find F, and unsure if i am even using the correct equation. where does the 3cm from the bend bit come into play if at all?
Relevant equations
F = IL x B
It is the force acting on a current carrying conductor in a magnetic field.
The correct equation is . deltaB = (mu)o/4pi{I*delta L*sin(theta)}/R^2
where (theta ) is the angle between (delta L) and line joining the point P and mid point of delta L and R is the distance between delta L and P.
ΔB = μo/4π(IΔLsinθ)/R^2
so I = 27
θ = 45
ΔL = 2mm?
and R can be found using trig.
so what is μ and o??
soz just really lost. any help would be great.
Field due to two elements =ΔB = 2[μo/4π(IΔLsinθ)/R^2]
= 2[10^-7*27*2x10^-3*0.707/(1.414*1.5*10^-2)^2]
= 16.968x10^-6T
