What Is the Speed of the Rod's Tip When Released from a Horizontal Position?
The discussion focuses on the dynamics of a thin, uniform rod with moment of inertia I = 1/3ML², pivoted at one end, and a metal ball of mass m = 2M attached at a distance d from the pivot. When released from a horizontal position, the speed of the rod's tip at the vertical position is derived as v = √(3gL)√((1 + 4(d/L))/(1 + 6(d/L)²). Additionally, the discussion addresses finding the value of d/L where the speed of the rod matches that of d = 0, identifying this point as the center of percussion or "sweet spot" of the rod.
  • Understanding of rotational dynamics and moment of inertia
  • Familiarity with energy conservation principles in mechanics
  • Knowledge of angular velocity and its relationship to linear velocity
  • Basic algebra for manipulating equations involving ratios and square roots
  • Study the derivation of the moment of inertia for different shapes, focusing on rods and disks
  • Learn about the conservation of mechanical energy in rotational systems
  • Explore the concept of the center of percussion in rigid body dynamics
  • Investigate the effects of mass distribution on the dynamics of pivoted objects
Physics students, mechanical engineers, and anyone interested in the principles of rotational motion and energy conservation in mechanics.
skateza
A thin, unirform rod (I=1/3ML^2) of length L and mass M is pivoted about one end. A small metal ball of mass m=2M is attached to the road a distance d from the pivot. The rod and ball are realeased from rest in a horizontal position and allowed to swing downward without friction or air resistance.
a) show that when the rod reaches the vertical position, the speed of its tip is:
v = [tex]\sqrt{3gL}\sqrt{(1 + 4(d/L))/(1 + 6(d/L)^{2})}[/tex]
b) At what finite value of d/L is the speed of the rod the same as it is for d=0? (This value of d/L is the center of percussion, or "sweet spot" of the rod.)
For part a i know its Ei = Ef, but I am not sure what you should be using to calculate it..
The rod has Ei = MgL, and [tex]Ef=1/2I\omega^{2} + Mg(L/2)[/tex] But i don't know what i should calculate for the ball, potential at the top and rotational kinetic at the bottom?
i haven't even looked at part b yet.
bump?
