Significance of a singular matrix
  • Context: Undergrad
  • Thread starter Thread starter transient_itch
    Matrix Significance
The discussion revolves around the implications of having a singular matrix in the context of a system of equations derived from force and moment equations. Participants explore the significance of singular matrices, potential redundancy in equations, and methods to address the inability to invert such matrices.
  • Technical explanation, Debate/contested, Mathematical reasoning
  • One participant notes that a singular matrix does not have an inverse, indicating that the equations represented by the matrix may not be independent.
  • Another participant suggests that singularity can imply redundancy in equations or a statically indeterminate problem.
  • A different viewpoint introduces the idea that singularity can be analogous to discontinuity in physical systems, using a black hole as an example.
  • Several participants propose numerical methods such as Gauss-Seidel and Jacobi iteration as potential solutions to find approximate values for the variables.
  • One participant mentions the Moore-Penrose pseudoinverse as a method to find a solution that minimizes the error in terms of L2-norm.
  • There is a discussion about the applicability of various methods for solving systems with singular matrices, with some participants asserting that the Moore-Penrose pseudoinverse is the most reliable approach.
  • Another participant raises a question about whether the proposed methods are effective when the matrix is singular.
  • One participant suggests that the problem may stem from an overconstrained system, drawing an analogy to defining a plane with four points.
Participants express differing views on the implications of singular matrices and the effectiveness of various methods for solving related problems. There is no consensus on a single approach or solution.
Participants mention various numerical methods and their applicability, but there is uncertainty regarding their effectiveness in the context of singular matrices. The discussion includes assumptions about the nature of the equations and the system being analyzed.
transient_itch
So I have a system of equations (composed of force and moment eqns) and I can split them up into matrices which will then look like this:
Ax = B
I know the matrices A and B are correct, because when I plug in known values for x from a working prog, I get the correct values for B. So that must mean A and B are correct, right?
HOWEVER, I am not able to invert A so that I may solve x = inv(A) * B.
The determinant of A is 0, so it's a singular matrix.
So what is the significance of an singular matrix?
Maybe there are redundant eqns involved? Am I looking at a statically indeterminant problem?
How does one fix this?
Ax = B
A singular matrix doesn't have an inverse! And yes, that means that the rows making up the matrix A are not independent which, in turn, means that the equations you are using are not independent- at least one is just a combination of the others. You don't have enough data to solve those equations.
Singularity of a matrix means that it becomes discontinuous at that point: take for example a black hole: it has a radius zero, which means that its gravitational force becomes undefined then; the same case here is when the adjoint of the co-efficient matrix we got is to be divided by the inverse, which is zero. Thus, the matrix is undefined there.
This is not a dead end :smile:. We have numerical methods like Gauss-Siedel and Jacobi iteration to find out the solution, that is, X.
let the eqn be of 3 variables, i.e., f(x1, x2, x3) = 0.
then we can write it as:
a11x1 + a12x2 + a13x3 = b1...1
a21x1 + a22x2 + a23x3 = b2...2
a31x1 + a32x2 + a33x3 = b3...3
then take initial gues values of x2(0) & x3(0). Put in eqn 1 n get x1(1).
Put x1(1), x3(0) n get x2(1) from eqn 2.
Put x1(1), x2(1) n get x3(1) from eqn 3.
Now we have the second guess values as: x1(1), x2(1) & x3(1).
Relaxation: x1(after iteration) = (some weightage)*x1(after iteration) + (1-weightage)*x1(before iteration).
same for x2 and x3.
Repeat the iterations till you get:
abs{x1(k+1),x2(k+1), x3(k+1) - x1(k),x2(k),x3(k)} < tolerance.
this will be your final set of x1, x2, x3 values.
Hope this helps.
The jacobi iteration is simpler than this: Google it yourself.
here's a reference: http://www.math-linux.com/spip.php?article48
Hello,
I don't know what is your application, so my hint maybe not be useful.
However, if you cannot invert that matrix you can still find the pseudoinverse of A (a.k.a. Moore-Penrose inverse, or generalized inverse).
This will give you the vector x which "gets closest" to the solution in terms of L2-norm. Namely, it is a closed form solution for the following:
[tex]{argmin}_{x}|Ax-b|_2[/tex]
See: http://en.wikipedia.org/wiki/Moore–Penrose_pseudoinverse
WELL, THERE IS A LOT OF WAYS TO SOLVE YOUR PROBLEM!
First Gauss-Seidel, then Jacobi.
Now Moore-Penrose.
I just remembered one more: Gauss-Jordan elimination method of finding a MATRIX INVERSE
http://mathworld.wolfram.com/Gauss-JordanElimination.html
P.S.: ARE YOU AN ENGINEERING STUDENT?
try using a software named MATLAB: it has readymade methods of finding matrix inverse if you don't need to show to your professor/teacher how you got the answer matrix: X
Are you sure the methods you mentioned still work when the matrix A is singular?
I thought the Moore-Penrose pseudoinverse was the only one that provides the "best solution" in terms of least squares.
Keep also in mind that the Moore-Penrose pseudoinverse works also when A is not a square matrix!
cent percent sure! we have used it in our FORTRAN classes to solve sums... fresh out of grad...can't be mistaken
That means your truss topology or whatever you are working on is overconstrained. Similar to defining a plane with 4 points.
