Calculate Heat Required to Raise Water Temperature: 5kg, 60° to Boiling Point
  • Thread starter Thread starter jack1234
    Heat
The discussion revolves around calculating the heat required to raise the temperature of 5 kg of water from 60° Celsius to its boiling point. Participants are exploring the application of the heat transfer formula and the conversion between units of energy.
  • Mathematical reasoning, Assumption checking
  • Participants are attempting to apply the formula Q=mcdeltaT and questioning the accuracy of their calculations and the provided answer options. Some are clarifying the boiling point of water and the definition of Delta T. Others are discussing unit conversions and the potential inclusion of latent heat.
The discussion is active, with participants providing calculations and questioning the correctness of the original answer. There is a mix of interpretations regarding unit conversions and the formula application, but no consensus has been reached on the final answer.
Some participants express uncertainty about the boiling point of water and the significance of unit conversions in their calculations. There is also mention of significant digits and the potential impact of including latent heat in the calculations.
jack1234
How many calories of heat are required to raise the temperature of 5 kg of water from 60° to the boiling point? Select the correct answer.
a. 4.2 x 10^5
b. 2 x 10^5
c. 7.5 x 10^4
d. 18 x 10^5
e. 420
The answer is a, but what I calculate
Q=mcdeltaT
=5*4186*1
=20930
is b, am I doing anything wrong?
What is the boiling point of water?
What is Delta T ?
Em, i suppose you mean [tex]Q=5*4186*10[/tex] and in that you included your division by four to change the joules into calories.
I can't see anything wrong anyways, unless it wanted you to include the latent heat of vaporization into the formula, though I doubt that would change your answer by much.
I may be wrong too though..
O...I think the answer in original question is not correct, it should be
it should be
Q=5000g * 1 J/(calories*celsius) * 40 celsius
=20000J
However the answer is still b though, what is the problem?
You're quite close, but I have the feeling you're mixing up your units.
Here's the correct calculation (note how I leave in the units and let them cancel at the end).
Q = m * C * dT
= 5 kg * 4186 J/(kg C) * 40 C
= 837,200 J.
Now taking 1 cal = 4.184 J (which seems to be the accepted value),
Q = 200,095 cal = 2 x 105
in the correct number of significant digits.
So the answer is b) -- if it says it's a) then it is wrong :smile:
  • · Replies 18 ·
