| Thread Closed |
Max voltage safe for all electronic devices? |
Share Thread | Thread Tools |
| Nov8-07, 05:00 AM | #1 |
Hi:
What is the maximum voltage possible *without* doing any of the following to any extent?: 1. Exceeding the dielectric strength of any electronic component 2. Generating temperatures above 70 Fahrenheit in any electronic component 3. Ionizing any electronic component Thanks, Radium |
| Nov8-07, 09:42 AM | #2 |
Recognitions:
| Nov12-07, 05:00 AM | #3 |
Green Xenon [Radium] wrote:
> What is the maximum voltage possible *without* doing any of the > following to any extent?: > 1. Exceeding the dielectric strength of any electronic component > 2. Generating temperatures above 70 Fahrenheit in any electronic component > 3. Ionizing any electronic component Essentially zero Volts, if you truly want to handle any component. For instance, given an "electronic component" consisting of 1 inch of no. 30 wire, an applied voltage of a few millivolts will induce several Amperes to flow, causing the wire to overheat and perhaps explode. It is pretty much impossible to establish the general sort of maximum you seek. While dielectric strength is usually related to applied voltage, heating is usually related to applied power, and ionization is quite subtle (except inside vacuum tubes, it rarely occurs in ordinary electronic systems).... Tom Roberts |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Max voltage safe for all electronic devices?
| Electronic Devices byfloyd Problem | Introductory Physics Homework | 0 | ||
| S4 helix of voltage-gated channels is the voltage sensor of the channel | Biology | 1 | ||
| voltage/current div on memory devices | Electrical Engineering | 0 | ||
| Maximum safe level of Electrical Voltage | Electrical Engineering | 18 | ||
| Any electronic storage devices using more than 2 variables? | Computing & Technology | 8 | ||
