Password Combination
by Omnis
Tags: combination, password
Omnis
Omnis is offline
#1
Nov8-07, 08:28 AM
P: 3
How do I work out password combination probabilities?
For example, I'm looking for a password between 10-15 characters in length, the password can contain any alpha-numeric character (lower/upper alphabet character and 0-9 digits). How would I find out how many possible combinations there are?
Phys.Org News Partner Mathematics news on Phys.org
Researchers help Boston Marathon organizers plan for 2014 race
'Math detective' analyzes odds for suspicious lottery wins
Pseudo-mathematics and financial charlatanism
DaveC426913
DaveC426913 is offline
#2
Nov8-07, 08:44 AM
DaveC426913's Avatar
P: 15,325
What would you make for an answer as your first try? What logic did you use?
Hint:
How many possibilities are there for the first number in the sequence?
How many possibilities are there for the second number in the sequence?
Hw many times do you have to do this?
What is a really compact way representing that as a generalized formula?
Omnis
Omnis is offline
#3
Nov9-07, 05:24 PM
P: 3
Quote Quote by DaveC426913 View Post
62
62
How many times do you have to do this?
10-15 times depending on the password length
I have no idea, thats why I came here, I'm wondering if its possible to recover a zip password on one of my files but I need to know how many possiblilities there are and I also like to know how to work it out for myself :)
DaveC426913
#4
Nov9-07, 05:49 PM
P: 15,325
OK, well there's
62x62x62x62x62x62x62x62x62x62
62x62x62x62x62x62x62x62x62x62x62
62x62x62x62x62x62x62x62x62x62x62x62
62x62x62x62x62x62x62x62x62x62x62x62x62
62x62x62x62x62x62x62x62x62x62x62x62x62x62
62x62x62x62x62x62x62x62x62x62x62x62x62x62x62
or
62^10 + 62^11 + 62^12 + 62^13 + 62^14 + 62^15
or
a little more than 781 septillion
combinations.
At one try per second, it will take you a mere 24 quadrillion years, a mere 1.8 billion times longer than the universe has existed to-date.
Don't try to do them all in one sitting.
CRGreathouse
CRGreathouse is offline
#5
Nov9-07, 10:14 PM
Sci Advisor
HW Helper
P: 3,680
If you try ten billion passwords in a second with a given computer, and you use a million computers, it would take 1238 years on average.
JasonRox
JasonRox is offline
#6
Nov10-07, 12:12 AM
HW Helper
PF Gold
JasonRox's Avatar
P: 2,328
OK, well there's
or
or
combinations.
After the 10th character the user has the option not choose at all, so that is 63 choices.
ben328i
ben328i is offline
#7
Nov10-07, 12:51 AM
P: 22
isn't there a formula for that from allg or something.
what is the equation not worked out like in a, b c, etc. form.
HallsofIvy
HallsofIvy is offline
#8
Nov10-07, 07:00 AM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 38,879
The "formula" DaveC426913 was using earlier is often referred to as simply "The Fundamental Counting Principle": If you can do A in "n" ways and you can do B in "m" ways, then you can do A and B together in "mn" ways.
If you have 62 symbols you can use and there are no restrictions on how they can be used, then you have 62 ways you can write each of the, say, 10 symbols and so have
6210 possible 10 letter "passwords".
Similarly, there are 6211 possible 11 letter "passwords", 6212 12 letter "passwords", 6213 l13 letter "passwords", 6214 14 letter passwords,, and, finally, 6215 15 letter "passwords".
Altogether, then, there are a total of 6210+ 6211+6212+6213+6214+_6215 "passwords". That's the figure DaveC426913 gave.
JasonRox]After the 10th character the user has the option not choose at all, so that is 63 choices.
But if the user chose no character for the 11th choice, he must make the same choice for the 12th, 13th 14th, and 15th. I don't think that simplifies anything.
ben328i
ben328i is offline
#9
Nov10-07, 01:57 PM
P: 22
ha good luck if this is really a problem not just a question.
DaveC426913
#10
Nov10-07, 02:14 PM
P: 15,325
Quote Quote by JasonRox View Post
What? No.
If the pw is 10 characters long, there are 62^10 possible combinations.
If the pw is 11 characters long, there are 62^11 possible combinations.
etc.
Add them together and you get all possible combinations within the parameters set.
So, your scenario where the user decides to not choose at all after the tenth character (or more accurataly: hits return), is simply the scenario where the pw is only 10 characters long.
Omnis
Omnis is offline
#11
Nov12-07, 09:35 PM
P: 3
Thanks to everyone for the help
Quote Quote by ben328i View Post
It is a problem, I'm trying to recover a password for a zip file, but the luck is much appreciated
JasonRox
JasonRox is offline
#12
Nov12-07, 09:46 PM
HW Helper
PF Gold
JasonRox's Avatar
P: 2,328
What? No.
etc.
You're right!
I never thought about that.
DaveC426913
#13
Nov12-07, 10:08 PM
P: 15,325
Quote Quote by Omnis View Post
If it's your password, that should eliminate about 99.999999% of the possibilities, shrinking it to ones you would have come up with.
If it's not your password... well, that's raises an intriguing question...
JasonRox
JasonRox is offline
#14
Nov12-07, 10:10 PM
HW Helper
PF Gold
JasonRox's Avatar
P: 2,328
Yeah, you can eliminate the characters you know for sure you didn't use!
wysard
wysard is offline
#15
Nov13-07, 12:49 AM
P: 172
Assuming order is important, ie:that "BAT" is not the same as "TAB"
then the general answer is n!/r! or:
62!/ (pwd length)! Where "!" means the factorial function.
Just like picking a lottery number.
PS. It's easier to break the password encryption scheme than guess the actual password.
Dantie Neit
Dantie Neit is offline
#16
Nov15-08, 09:29 AM
P: 1
Figured I'd use this one. I'm trying to crack my password for something I got years ago, but I don't know how worth it it is. I need to know the number of possibilities for a 4 character password which has 6 characters to use. Basically 1111 to 6666. I'm good at maths, but that's only at a low level still. If someone can just work out what it is, that would be great.
Cheers!!!
slider142
slider142 is offline
#17
Nov16-08, 08:21 AM
P: 876
Use the Multiplication Principle of Counting: You have 6 choices for the first character, 6 choices for the second character, 6 for the third, and 6 for the fourth, so altogether you have 6*6*6*6 choices for a string of 4 characters.
The principle comes from the following thought experiment. If you have a string of two characters with m choices for the first character and n choices for the second character, then first counting all possible strings starting with characters in the first space. For each character in the first space, there will be n possibilities for the second space. Ie., if the first character can be any letter in the alphabet, you would have sets like {A_, A_, ...}, {B_, B_, ...}, ... ,{Z_, Z_, ...} where the underscores are replaced by characters from the second set (of size n). Thus, you should have m sets of n strings, or m*n total strings.
HallsofIvy
#18
Nov16-08, 01:02 PM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 38,879
Quote Quote by wysard View Post
No. That would be true if the same letter or numeral could not be used twice in the same password and that is not true.
Register to reply
Related Discussions
expired password??? Forum Feedback & Announcements 7
My password was changed. Forum Feedback & Announcements 4
Password General Discussion 1
Password Recovery Computing & Technology 7
