How Do You Calculate E°cell Values for Galvanic Reactions?
  • Thread starter salman213
In summary: G(3).So, summarizing, we have ΔG(3) = ΔG(1) + ΔG(2) and this is valid if ΔG is a state function (only initial and final state are important, not the path you have followed to go from A to B).In summary, the conversation discusses finding the E°cell for a galvanic cell based on the unbalanced reaction IO3-(aq) + Fe2+(aq) --> Fe3+(aq) + I2(s). The E°cell is calculated using the half reactions Fe3+ (aq) ---> Fe2+(aq) with an E° of +0.77V and IO3-(aq) ---> I
salman213
302
I needed to find the E°cell (always positive for a galvanic cell), based on the following (unbalanced) reaction:
So E°cell = Ecathode - Eanode
I made the half reactions
EØ = +0.77 V (i found this reaction in my table)
IO3-(aq) ---> I2(s)
balanced the 2nd one to
12 H + 2IO3 + 5e- ---> I2 + 6H2O
EØ = I cannot find this value in that table
I FOUND IT ONLINE ON A WEBSITE TO BE EØ = +1.19V, HOW DID THEY GET THIS VALUE! Anyone know?
Chemistry news on Phys.org
IO3-(aq) ---> I2(s)
2IO3-(aq) + 10Fe2+(aq) + 12H+ --> 10Fe3+(aq) + I2(s) + 6H2O;
E° = +1.19 - 0.77 = +0.42V.
About the reaction:
(1) 2IO3-(aq) + 12 H+ + 10e- ---> I2(s) + 6H2O
You can find its E° if you know the E° of other similar reactions from which you can get that one, for example:
(2) IO3-(aq) + 6H+ +6e- --> I- + 3H2O;_______>E°(2) = +1.08V
(3) I2(s) + 2e- --> 2I- ;____________________>E°(3) = +0.53V
Reaction (1) is given by: 2*Reaction(2) - Reaction(3) and so:
Delta G°(1) = 2*Delta G°(2) - Delta G°(3)
Now you use the equation: Delta G° = -nF*Delta E° where n is the number of electrons of the reaction, so you have:
-10F*Delta E°(1) = 2*[-6F*Delta E°(2)] - [-2F*Delta E°(3)]
10*Delta E°(1) = 12*Delta E°(2) - 2*Delta E°(3)
Delta E°(1) = (1/10)[12*Delta E°(2) - 2*Delta E°(3)] =
= (1/5)[6*Delta E°(2) - Delta E°(3)] =
= (1/5)[6*1.08 - 0.53] = +1.19V.
wowi would never have that of that...:S
how is the delta G of the first equation equal to the delta G if the second and third with those operations. Like how do we know to relate delta G?
Do you agree on the fact that Reaction (1) is given by 2*Reaction(2) - Reaction(3) ?
2*Reaction(2) = 2IO3-(aq) + 12H+ +12e- --> 2I- + 6H2O
- Reaction(3) = 2I- --> I2(s) + 2e-
Now you sum them:
2IO3-(aq) + 12H+ +12e- + 2I- --> 2I- + 6H2O + I2(s) + 2e-
you simplify canceling 2I- and 2e- on both members:
2IO3-(aq) + 12H+ +10e- --> 6H2O + I2(s).
About summing ΔG: if you have
(1) A --> B you know that ΔG(1) = G(B) - G(A)
(2) C --> D you know that ΔG(2) = G(D) - G(C)
(3) A + C --> B + D you know that ΔG(3) = G(B + D) - G(A + C)
But G(B + D) - G(A + C) = G(B) + G(D) - G(A) - G(C) =
= G(B) - G(A) + G(D) - G(C) = ΔG(1) + ΔG(2)
1. What is E°cell and why is it important?
E°cell is the standard cell potential or electromotive force of a reaction. It represents the maximum amount of work that can be done by a cell under standard conditions. Knowing E°cell is important because it allows us to predict the direction and feasibility of a reaction, as well as calculate the cell potential under non-standard conditions.
2. How do I determine the E°cell value of a reaction?
The E°cell value of a reaction can be determined by using the standard reduction potentials of the half-reactions involved. Subtract the standard reduction potential of the anode from the standard reduction potential of the cathode to get the E°cell value.
3. What are the standard conditions for measuring E°cell?
The standard conditions for measuring E°cell are a temperature of 25°C (298 K), a pressure of 1 atm, and a concentration of 1 M for all species involved in the reaction. These conditions allow for a consistent and comparable measurement of E°cell.
4. Can E°cell values be negative?
Yes, E°cell values can be negative. A negative E°cell value indicates that the reaction is not spontaneous under standard conditions and will only occur if the conditions are altered.
5. How can I use E°cell values to predict the feasibility of a reaction?
If the E°cell value is positive, the reaction is spontaneous and will proceed in the forward direction. If the E°cell value is negative, the reaction is non-spontaneous and will only occur in the reverse direction. If the E°cell value is zero, the reaction is at equilibrium and will not proceed in either direction.
9K
11K
